THE PICTURE SEEMS TO HAVE DROPPED A LITTLE BIT.IS THERE ANY WAY OF ADJUSTING THIS.WAS THINKING IT HAD SOMETHING TO DO WITH THE LENSE?
  • 760 Answers
Please include make and model of your set. This will help in diagnosing your problem.
Posted on Apr 01, 2011
I dropped my camera today. Seems like the lense
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Oct 30, 2009 | Canon PowerShot A80 Digital Camera
Lens are stuck out. screen says "lens error"
There could be two things causing this problem.
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can not take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard for a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal. Make sure to clean the outside of the lense when fully open and keep it clean always. If this did not help, read 2.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inspect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on the camera and your camera would be back to normal.
Good luck!!!!!!
Jun 11, 2009 | Olympus FE-270 Digital Camera
Sony cyber shot dsc-n2
1- some dirt somehow got on the outside of side of the lense. So the lense could not fully retract or open out. As a result you can take any picture. If the lense comes out even a little bit, try to pull it out NOT too hard a few times. If it does not retract, turn the camera off and push the lense in (up and down) NOT too hard foe a few times. If the camera opened up 100% or retracted 100%, your camera should be back to normal.
2- If you dropped the camera, some mechanical part of the lense is broken or dislocated or the cable may have come loose. In this case you need to take out the lense from the camera and inpect it for broken pieces or loose cable. clean the outside of the lense and push the lense in and out a few times. Put the lense back on and your camera would be back to normal.
Good luck!!!!!!
May 14, 2009 | Sony Cyber-shot DSC-N2 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
F--- shows up after cleaning. Lense loose?
Sometimes lens mount to camera can get loose but mostly lens has a electrical connection problem that you would be better off just replacing lens with a good used one from eBay.
Jul 08, 2017 | Nikon D100 Digital Camera
Sound is a little off from the picture
yes, if is still under warranty, you have to tell them the problem and let them fix it first.
Feb 20, 2008 | JVC AV27F577 27" TV
Toshiba MW27FPX dropped it!
See if you can borrow a TV de-magnetizer (degauss) from a tv shop...if that doesn't purify the color, then the shadow mask inside the picture tube is bad = no repair unless CRT is replaced
and that would cost more than a new TV ! ...................T.
Jan 30, 2008 | Televison & Video
Power/lens Problems
it seems that the lense movement is jammed. Have you dropped the camera? just have a close look from the front side of the camera, does the lense assembly seems to be pressed or moved aside by some extra preassure? if no physical disalingment is visible may be some sand or dust partical is obstructing the movement of the lense assambly. needs a help from camera repair shop.
Sep 08, 2006 | Sony Cyber-Shot DSC-P72 Digital Camera
Pentax Optio 330GS its gone blind!
You've probably got something as simple as a ribbon cable loose in the camera. Beware though, dismantling is a serious task unless you have experience. Amazingly the CCD is often connected in such a simple, analog-esqe, way that disconnecting it doesn't cause an error, just a black screen.
Sep 08, 2005 | Pentax Optio 330GS Digital Camera
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
