Question about Inglesina Classic Bassinet LG3 Carriage Stroller
I need to replace all four wheels on carriage
  • 844 Answers
Welcome to FixYa!
Here's how to remove the wheels of your carriage.
  • Make sure that the brake bar is positioned upwards (in position of brake-release).
  • Lift the frame base to remove one of the rear wheels D.
  • Pull upwards the lever M located on the wheel and pull the wheel out of the pin N.
  • Repeat the procedure also for the other wheels.
To place the wheel back, just reverse the procedure.
You can contact Inglesina for available parts (Wheels).
INGLESINA, USA INC.
300 Penhorn Ave, STE 2
Secaucus, NJ 07094
Ph: (973)244-2411
Fax: (973)244-1190
INGLESINA CUSTOMER SERVICE
Toll free ph: (888)542-1112 or (877)486-5112
I hope this helps.
Thank you for using FixYa.
Keep me posted.
Jas247
Posted on Apr 01, 2011
My 1989 jeep cherokee will only drive in 4x
Check the soildnoid that engages 4x4 by switching it from 2 to 4 wheel drive and listen to it 27 dollar part if needed to be replaced
Feb 25, 2014 | 1999 Jeep Grand Cherokee
Trying to adjust blade for first time but the rapidset blade tension lever doesn't seem to do anything.
I just bought the same item from Home Depot, and had the same problem. I called the help number in the manual and was told to return it. I was hesitant to do this because it seemed like a small problem, and I wondered if it wasn't a design issue. I subsequently dove a little deeper and dissassembled the upper wheel suspension to investigate. The hard part was removing the retainer clip on the upper wheel axle. Easy to do, but the inexperienced might be intimidated. Then four screws release the upper wheel carriage, and four more release the bracket holding the "Rapidset tension" mechanism. This mechanism is a spring loaded plunger operated by a cam attached to the hand operated lever. the plunger is supposed to engage a tab on the wheel carriage and force it downwards, but it is of crude design and poor conception. The plunger barely engages the tab and can easily slip behind it, and once this happens it will operate without effect. Also, the plunger is rather loosely held in place and can get cockeyed and jam. I considered various ways to modify or improve the mechanism, but found that by screwing the center dial in the back full clockwise, the upper wheel carriage would be tilted so that the Rapidset plunger would engage more or less reliably. I believe that this action should allow you to use the feature, provide that you manouver the plunger into place one way or another. I believe this can be done with a screwdriver or other probe without any dissassembly if you can locate it visually behind the spokes of the upper wheel.
I have to say, from my inspection of the mechanisms, and from the my first use of the tool, it seems to be a very reasonable design, but the obvious failings of this one little gizmo, which is touted as the trademarked "Rapidset" presents a puzzle.
Dec 12, 2010 | Ryobi 9 in. Benchtop Band Saw
The ribbon cassette is stuck to the far left and the machine is constantly beeping.
Remove the ribbon cassette and verify there is a print wheel in the machine."don't put the ribbon back in yet. Push the carriage part way over to the right, stop, then switch the power on. The carriage should go to the LHS and the print wheel should "home" itself. If the unit is beeping at this stage...check the flex multi stand cable coming from the carriage. On earlier models the wires could sometimes break a couple of inches from the carriage. The carriage and cable will have to be replaced if this is the case.
Jun 21, 2010 | Nakajima AE-710 Typewriter
The carriage keeps going back full force
Check that the carriage release levers have freedom are are not binding. Also the tab key and linkage, next the space bar mechanism. From under machine observe the escapement wheel, rocker and the escapement pawls (fixed dog and loose dog). Lubricate with 10 weight . oil only no WD 40). The loose dog is the part that holds the carriage in position by holding the tooth on the escapement whee wheel assembly. GOOD LUCK
Nov 14, 2009 | Office Equipment & Supplies
IBM Wheelwriter 10 Series II beeps
either the carriage home position sensor flag is broken or the daisy wheel can't find home. try removing daisy wheel and re-installit. turn unit on and see if daisy wheel spins if it does then the carriage home position sensor has a problem.
Nov 13, 2009 | Lexmark Wheelwriter 10 Series II...
I changed the ink cartridges and i can not get the
Do you mean you can't print text in black? You are correct to replace black ink. Turn off printer. Turn on printer, and immediately unplug power when carriage moving. So, carriage will stop not at parking position. Unplug usb. Move carriage freely bay hand.
Aug 12, 2009 | Epson Office Equipment & Supplies
Wheel replacement for older Peg Perego pram carriage
I have the same problem for a vintage 1860's Pedigree pram. Did you ever get the tires you needed?
Jul 31, 2009 | Peg Perego Elegante Stroller
Phil & Ted Vibe stroller,
I would suggest contacting the manufacturer of the carriage and requesting it be repaired under warranty.
Jun 03, 2009 | Philips Magnavox MWR10D6 DVD Recorder
My liftmaster garage opener just clicks when trying to open''
You probably have the lock enguaged. Press the lock button on the wall control for four seconds to turn lock off
Mar 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wheel replacements parts fo kensington pram
To find a new wheel for the stroller might be hard but I'm positive that you can find one on the internet where you bought it I would also try ebay.
Dec 26, 2007 | Silver Cross Durham Stroller
Inglesina Classic Bassinet LG3 Carriage Stroller Logo
125 people viewed this question
Top Inglesina Baby Gear Experts
Paul Carew
Dorel UK
Dorel UK
Are you an Inglesina Baby Gear Expert? Answer questions, earn points and help others
