Question about D-Link DCS-3420 Network Camera
Driver CD rom lost need dcs3420.exe - D-Link DCS-3420 Network Camera
Win 98 in dos mode i get this message " no cd rom or msdex.exe is not loaded " when trying to acces game disk in cd rom
1) Does it say MSDEX.EXE or MSCDEX.EXE?
2) Have you ever used that CD successfully on that computer before? (DVD's don't work well in MS-DOS).
3) Verify its trying to run from the correct drive. D:, E:, etc...
That aside, I'd recommend a glance at the following support page. It sounds like your driver isn't supported or your game is referring to a specific drive that doesn't exist.
MSCDEX Help
(make a back-up copy your autoexec.bat, and rename it autoexec.bat.orig just in case)
Get an older compatible driver for your CD-Rom that is windows 98 compatible, so something around the year 2000 is probably ideal.
Uninstall your current driver and reboot. Scan for Hardware changes and install the new drivers for your CD-ROM. Then check your config.sys and verify the driver. If its not correct, open the autoexec.bat in an editor. in the portion of the autoexec.bat that has MSCDEX..exe program you'll put in the following. (replace DRIVERNAME with the driver name, typically MSCD001)
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:DRIVERNAME
Save, reboot. Let me know how it goes!
Feb 08, 2013 | Computers & Internet
Tip
HP printer UNINSTALL using CD
<p><span><b>Resolution:</b></span><br /> <ol> <li> <span>Run the uninstaller from the SETUP.EXE driver</span> <li> <span>Delete printer from Printers folder</span></li></ol> <p><span><b>Removing printer using the SETUP.EXE driver:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver as copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <p><span><b>Deleteing Printer:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver was copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <br />
on Mar 10, 2011 | Office Equipment & Supplies
LOST CD ROM FOR MFC 260C AND I NEED TO REINSTALL IT
For whatever reason, the brother US site does not have the MFC-260C driver available. I managed to find it for you on their australian site. Just download the driver based on your operating system, double click on the .exe file, navigate through the options (most likely just taking the default unless you know what you're doing), and it should install the drivers for you. You can copy the .exe file to a flash drive or CD to install it on any other computers.
Aug 08, 2011 | Brother MFC-260C All-In-One InkJet Printer
I Have somehow lost the following file c:\windows\system32\r undll32.exe which is stopping me from getting into control panel etc
try this :
  1. Put the Windows XP CD ROM disk in the CD ROM drive.
  2. Click Start, and then click Run.
  3. Type expand X:\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
  4. Restart the computer.
Mar 07, 2010 | Sony VAIO GRZ610 Notebook
Lost install CD for Canon PIXMA MP160
This link is to the drivers for the MP160, you can then download the drivers to your pc and run them with a CD http://rapidshare.com/files/115660111/canonmp160.exe
May 17, 2008 | Cannon i70 Printer
INSTALLATION
techspot has a driver
try that one
Dec 14, 2007 | Computers & Internet
Cd rom
Where can I get the driver for my CD-ROM?
Visit our hardware download section to obtain a generic CD-ROM driver (oakcdrom.sys) and mscdex.exe if needed.
If you are looking for a specific driver for your CD-ROM drive or a Firmware update, please see our CD-ROM driver page.
Dont for get to Vote / Merry Christmas.......Good Luck!
Dec 06, 2007 | Computers & Internet
Can you help set up?
Is the CD ROM recognized in 'My Computer'?
Are other CDs able to run?
If not, ununstall CD ROM drivers, shutdown and restart, CD drive should then self install.
You can update ALL your drivers with this new program.
versiontracker Pro $29.95
http://www.versiontracker.com/windows/
"Keeping your software and drivers current helps keep your PC running smoothly, but locating and matching the right updates for your machine can be frustrating and time-consuming. With versiontracker Pro, you don't need an IT department. versiontracker Pro scans your hardware AND software to determine the right updates for your drivers and applications."
(Quote from website)
Nov 02, 2007 | Cosmi Greeting Card Magic for PC
D-Link DCS-3420 Network Camera Logo
158 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
