Question about Ovens
Hi, I have an OV851series Baxter Oven. The Auto-Start was not working a year ago and the control board V10-138 was reolaced. The auto-cycle worked for a year and now it is no longer working again. Same problem as before. Is the problem the Time keeper Ram IC? I'm thinking the Lithum batter on M48T08 has gone bad. Is there a schematic for the controller borad or any other information you can provide.? Thanks for your help, Al
3 Suggested Answers
fixyourboard
  • 310 Answers
SOURCE: My Whirlpool oven stopped heating. The control
There is a thermal fuse mounted on the back of the oven that feeds power to both elements. This fuse has open up. The control panel gets power via a different path and still lights up.
Posted on Jun 25, 2010
espressonist
  • 1711 Answers
SOURCE: I have BAXTER Oven OV85OG-M36 91531 4-23-91 3500 naturaL 3.5 AUTO//MANUAL
Can you please describe the problem more clear since we can not clear it out.
Remain
Posted on Aug 23, 2010
Baxter oven not working
Hobart owns Baxter. You'll have to call Hobart.
Feb 14, 2014 | Baxter Ovens
Jenn air svd46800 oven not working
Good Afternoon,
The control boards in your appliance may have failed. There is a display board, part number 71001799 and relay board part number 12001693. Commonly we see transformers on these relay boards fail with power surges. Luckily, we do test and repair these parts. Remanufacturing these controls will save you the high cost of buying new, and each rebuild will come with a 2 year warranty-- which is three times longer than new. Email me if you have any questions! info@fixyourboard.com
Jun 05, 2017 | Jenn-Air Ovens
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
Where can i go and dowload the wiring manual for the baxter gas oven
Hobart, the parent company of Baxter are very picky with releasing manuals, diagrams, etc. Your best bet is go to the link below and create a user name and see if they give you access to the manuals.
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2FPagesZ2FInstructOperManuals.aspx&reason=0&formdir=2
Nov 14, 2011 | Baxter BXA2G Stainless Steel Gas Single...
I used my auto self clean on my whirlpool electric oven for the first time, now my oven is off, has been for 6 hrs and the door is stuck closed. how do i turn my oven back on?
Hello there and welcome to fixya
oko well to tell you the truth the cleaning cycle is the hardest cycle for the oven due to the extreem heat during the clean cycle.
Any way the way to unlock the door is as follows
unplug the oven for at least 1 hour then after the hour is over plug it back in and then you may hear a beep if so simply press the cancel button and then unlock the oven door as you would normally do now you may even have to wait for 5 min once you plug it back in but normally it works right away
Now if this doesent work than you may have a faulty controle board this is very common because of the extreem heat and some of the board parts cant take the heat whirlpool is still trying to fix this issue this has been a problem for some time ok?
any way i hope this helps please keep me posted on how this is going
Best regards Mike
Sep 22, 2011 | Whirlpool Ovens
I have a Baxter oven OV210G, When the door is open the rack will not stop or lower. The micro switches all work and relays seem to work but I can't find the MR3 cantactor and don't if that is the problem...
When you open the door check to see if your burner and circulation fan remain on, if they do you have an issue with your door switch.
Also if your rotation micro-switch was bad you would get a buzzer every 1 second because the oven would think the carrier isn't rotating.
It's hard to troubleshoot beyond that without seeing the oven, its possible you could have a bad relay on your control board. In this case I would call an authorized service provider to have to check the oven out.
Dec 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
My Whirlpool oven stopped heating. The control panel works/lights up. When you turn on the bake oven and start it appears to be working and you can feel the a motor running however neither of the elements...
Jun 25, 2010 | Whirlpool RBS305PDS Electric Single Oven
Jenn-air dbl oven WW30430B. Lower oven doesn't work anymore. Try to pre-heat - get F2 message. This started a year ago. Shortly after onset we had a hurricane and were without power for 2 days. When power...
HI. the oven control will interrupt normal actions if it senses an abnormal oven temperature. this can be caused by a faulty RTD(temp sensor), and, also, a faulty relay board if present.
Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness to make sure it is in good condition.
Aug 04, 2009 | Ovens
Oven will not stay on
HI. this is a control fault that can be confirmed by unplugging the unit for 5 minutes. if the control continues to cycle from auto to manual, replace the control board(EOC/Clock)
May 28, 2009 | Ovens
Baxter ov300e electric oven
When you say the oven doesn't want to turn on are you referring to the control board wont turn on? Or are you saying that the oven wont heat when it gets too hot?
Oct 19, 2008 | Baxter OV300E Stainless Steel Electric...
Ovens Logo
60 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
