Question about Canon PIXMA MX310 All-In-One Printer
Printer paper is jamming and code 5100 flashes
    Problem Solver:
  • 6 Answers
Try this
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
presses of the RESUME button. To confirm, press POWER once.
Posted on Apr 01, 2011
My HP Laserject 5100 Printer has the Paper Jam Problem. After that, I check printer. But i haven't seen any paper jam. When i print out, nothing show on paper and show the paper jam.. How to fix?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Jul 04, 2011 | HP LaserJet 5100 Printer
I tried to print something and the paper got jammed and now I have an error code 5100. What does this mean and how can I clear it? I have removed the jammed paper. please help me
the solution is to clean the strip film,look for the paper sensor is not broken or blocked
5100 means
- Carriage unit
- Timing **** film
- Logic board
- Carriage motor all this
Feb 24, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I have an error code 5100. It started grabbing the paper wrong and a piece got jammed. I removed it and then it says error 5100. I have turned it off and on a few times and it is still there.
Nov 04, 2010 | Canon PIXMA MP470 All-in-One Printer
Canon MP830 will not print Error code 5C10, And 5100 donaldbetty@juno.com
5C10 seems to indicate a paper jam. 5100 indicates either a paper jam or ink tanks not seated properly.
A) Paper jam: There is a rear cover on this model. Many paper jams cannot be seen from the outside. Sometimes even a scrap of paper from a previous jam will disrupt the paper path.
B) Follow your manual for installation of the ink tanks. Remove and replace the ink tanks carefully following the instructions.
C) Should these remedies not fix the problem, you can try resetting the device:
1) Press and hold the <On/Off> button until the display on the machine goes blank. (If this is unsuccessful, unplug the power cord).
2) Wait approx. 10 seconds and power back on. Wait until the printer completes its startup routine before trying another print job.
3) If solution fails, your MP 830 may require repair
Dec 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 19, 2009 | Canon PIXMA MP510 All-In-One InkJet...
Alarm is flashing error code 5100 and won't let me print anything
- Carriage unit
- Carriage motor
Nov 04, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Paper jam on canon pixma mp600
Hi You can Try
Error Code 5100
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Jun 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon mx700 5100 error
The 5100 error usually indicates a problem with the printer knowing where the printhead carriage unit is.
Chances are that when you cleared the jam you dislodged, damaged or otherwise skewed the little calibration strip at the back of the printer.
This strip is a clear bit of plastic that has lots of thin black lines on it and it's used by the printer to sense where it is.
If it's not that then it's most likely something jamming the printhead carriage somehow... ink soaked bits of paper are a favourite that I used to miss a lot.
Hope that helps.
Jan 30, 2009 | Canon MX700 Office All-In-One InkJet...
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
60 people viewed this question
old marine
old marine
