Question about John Deere Radiator 4010 Gas And Diesel ()
John deere 4010 wiring schematic,diesel engine 24volt starter 12 volt charging systems need to rewire the starter ,voltage regulator,series/parralell switch
Call me, or email me there are so many options, I would like to know exactly what you need. Solutions are simple, I have worked on AC and DC vurrent all my life and even have some designs on youtube, and have taught seminars for Delco, Leece-Neville/Prestolite, and designs for A/P and Twin Roter. Shmburns@yahoo.com
Posted on Dec 24, 2011
My john deere z445 won't start. makes ticking noise. what is the problem?
Confirm that engine will rotate.
Confirm voltage at battery during crank attempt minimum 9 volts at crank, 12 volts at rest.
Confirm greater than 9 volts at starter when cranking.
Jun 29, 2017 | John Deere Garden
There are two yellow wires and 1 red wire on a voltage regulator on a Briggs and Stratton 22hp. The the mower flooded recently.
the two yellows go under the flywheel to the stator , they are a/c current that is converted to 13.8 volts D/C in the voltage regulator .I would not think it being under water would hurt the stator or regulator . Maybe the mud under the flywheel might grind things.
Aug 27, 2016 | John Deere Riding Lawn Mower. EZtrak Z425...
Model 170 with a Kawasaki 14 hp engine. Why doesn't anything happen when I turn the key?
This is a 12 volt system and the battery should have 12 1/2 volts. Motor running the voltage should be above 13 volts and below 14.5 volts. You will need a battery charge or jump start.
Mar 29, 2016 | John Deere Garden
I have a 2008 la 115 john deere riding mower. It won't start in less I put a large screwdriver on the solenoid. the fuse looks good as well. I replaced the ignition switch and solenoid too.
When you try to turn over engine with key it turns over slowly and stops? It acts like starters not working properly? If this sounds like it and it's a single cylinder Briggs and Stratton engine ohv's your valve specs are off they need to be checked and adjusted every 200 hrs. If you need further assistance let me know. Wadembly@aol.com or call 831-578-4034 pacific standard time ( California)
May 18, 2015 | John Deere Garden
1979 Dodge CB300
1979 CB300 or B300? It's been many years so I really don't remember but, it sounds like the voltage regulator has stopped working. Like I said, I can't remember but the voltage regulator is either built into the alternator or it's mounted on either the fender near the battery or on the firewall. This is a simplified schematic but you should understand. Also once you find the voltage regulator see if you can remove the cover and clean the contacts before you go and buy a new one. Hope this helps.
Nov 09, 2013 | Dodge Cars & Trucks
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
I have a 3010 John Deere +24 volt pos ground how do I change from 24 volt gererator to a 24 volt altenator
The 3010 24v JD system is not a true 24v system. It is a balanced split 12v system, with one positive ground battery and one negative ground battery. The only 24 volt accessory is the starter, where the batteries meet in a series to provide 24 volts for starting. All other accessories are 12v, half powered by the positive ground battery and half powered by the negative battery. The generator charges one battery in one direction and the other battery in the reverse direction. Therefore a 24v alternator is not easily adapted to this system.
The usual solution is to change to a 12v system with an alternator, changing the starter to 12v and changing the polarity of the positive ground battery to negative ground.
The cost of a 12v starter and alternator is far less than the cost of a 24v alternator, plus the added benefit of using 12v lights and other accessories.
JD switched to this 12v type of system with alternator during the 20 series production, but used two 6v batteries in a series due to the larger cranking amp rating of the 6v batteries occupying the same physical space.
Jan 10, 2011 | John Deere 4020 Gas & Diesel Tractor...
John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Sep 23, 2009 | Garden
John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
May 08, 2009 | Garden
John Deere Radiator 4010 Gas And Diesel () Logo
1,517 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
