Question about KitchenAid Food Mixers
Mixer is 'jumpy' even when locked in place? Is there an adjustment or tightening or something?
2 Suggested Answers
SOURCE: Kitchenaid Classic -Mixer Head wobbles or shakes back and forth
Lay the mixer on its side and look up through the base. You willnotice a small set screw. This holds the pin tight. If the set screw gets loose the pin willl begin to move out and the head will wobble. Simply tighten the set screw. I just did this to my Kitchenaid mixer 10 minutes ago and it now works fine.
Posted on Jan 13, 2011
The pin that connects my kitchen aide mixer to the base. I am unable to put it back in. Something seems to be blocking y. The hole looks like it is aligned
The hinge pin is normally locked in place by a screw. If that screw is not loosened enough the pin will not be easy to put back in place.
Put the mixer on its side and look through the base. You should see the screw, Loosen it and the hinge pin can be slid into place (make sure the pin's hole in the case and the one in the head line up). Once the hinge pin is in place, tighten the screw to secure the pin.
Dec 31, 2017 | Food Mixers
How to I install a cotter pin that came out?
Are you are referring to the pivot pin that joins the mixer head to the stand?
If so, it can be slid in place after you turn the whole mixer on its side and look up the underside of the stand. There is a screw which locks the pin in place. Loosen the screw and the pin will go into place. Tighten the screw afterwards.
Jul 24, 2014 | KitchenAid Kitchen Aid K45SSWH Classic...
How to tighten kitchenaid mixer motor head locking lever?
Adjust the head height first, flat paddle should just clear the bowl. Te head height adjustment can be seen in by the hinge looking from the front when the head is raised. Screw in (clockwise) to lower and out to raise. You cannot get the head lock right when head height is miles out
Jul 10, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Hobart a200 first gear not working
slacken the big acorn nut away from the bottom of the planetary and then tighten the lock nut to the acorn nut. When adjusted and secured, the planetary should have a little vertical play, maybe 1/16".
That will stop the second gear driving from friction from being too tight.
Feb 27, 2014 | Hobart A200 Stand Mixer
K45SSWH bowl clearance issue (different)
Check the following link for diagrams and parts list for you mixer.
http://www.partselect.com/Models/K45SS/Manufacturer/3/
Good luck on your project
Dec 06, 2013 | KitchenAid K45SSWH Classic 250-Watt...
The top part of the mixer has about 1/2 inch play and must be lifted in order to put in lock position
It sounds like the bar that the head hinges on has come out. It is located on the base and should be flush with the side of the mixer on both sides. Just knock it back into position and then turn the mixer over to tighten the screw that holds the hinge pin in place. It might also be that you need to adjust the height of the head by turning the adjustment screw on the hinge. Lift the head and the adjustment screw should be visible.
Jan 28, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
The tilt-up head on my KitchenAid KSM90 stand mixer has a lot of free play, the head moves (bounces)up & down when mixer is in use. Adjusting the beater for clearance using the dime method, when you...
The head bounce sounds as if the locking hook is not engaged properly when you slide the head-lock lever to the locked position.
If this is the case, you will need to disassemble the mixer to make sure the link from the lever to hook is not bent. Another possibility is that the slot in the base the hook engages. If this is broken away, the hook will not be able to hold the head in place (I sure hope that this is not the problem).
The Service Manual can be found at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Apr 04, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
The locking pin on the Kitchenaid Artisan mixer (KMS150) will not fully engage. The hinge pin had come out and we put that back in, not the lever will not fully engage.
I had the same issue. I just finished tearing mine apart only to find that the lock just wasn't engaging with a slot in the base of the mixer. Try lifting up the head of the mixer to expose the height adjust screw in the hinge between the base and the head. By tightening mine down a couple of turns, the lock can engage the slot again and the lock works. You may have to do a little tweaking to find the right balance between height adjustment and latch functionality, but at least you won't have to tear your mixer apart like I did!
Dec 14, 2008 | KitchenAid KSM150PS Artisan Series Stand...
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
If the beater to bowl adjustment quickly comes out of alignment, you may need to seek service. You may find a Kitchenaid certified service location locally at the following website:
http://caservice.kitchenaid.com/
Dec 14, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
Sep 23, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Food Mixers Logo
162 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
