Question about Motorola Talkabout T5820 (14 Channels) 2-Way Radio
I need to tune to a specific frequency, and i dont know which channels correspond to which frequency. the two way radio is motorola T5820 with 22 channelss
5 Suggested Answers
  • 20 Answers
SOURCE: what's the channel frequencies for a common 22 channel motorola 2 way vhf radio?
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Posted on Oct 12, 2007
Neto
  • 123 Answers
SOURCE: Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Posted on Feb 04, 2010
Testimonial: "Thanks for the response. appreciated it. It is very useful."
  • 22 Answers
SOURCE: Oops, misplaced my manual for
bobduffy39,
Channels are selected by tapping the center button once then using the arrows. The next tap of the center takes you to the CTCSS, DCS, and other functions follow. When scanning simply tap the transmit button and it should stop on the selected channel. Channels 8-14 are FRS channels at 500mw. These are the preferred channels to use for most people. 1-7and 15-22 are considered GMRS and requires a FCC License. Many people have been known to use these channels without having the license. This form of pirating is not recommended. I have included these links which could be of help to you.
To find a PDF Manual for Midland LXT310:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
To locate information on obtaining a GMRS license:
http://wireless.fcc.gov/services/index.htm?job=service_home&id=general_mobile
JTRadiojunkie
Posted on Sep 01, 2010
SOURCE: XU2100 (1 Channel) 2-Way Radio: How do I change frequency on a motorola xu2100...
Hello, I just purchased 3 of the discontinued XU2100 radio's, Can someone help me to change the frequency on them? My email address is cubnboy@yahoo.com. Thank u for your time...
Posted on Feb 22, 2011
I have 2 VISAR HANDIE-TALKIE FM RADIOS MODEL: HD5RDD9AA4AN + DON'T KNOW HOW TO PROGRAM THEM TO THE SAME CHANNELS
This is a discontinued radio from Motorola. programming requires a cable to connect to a computer, there is no direct programming available.
While this is not really an answer, the programming software is specific to Motorola and you need to buy both the software and the cables from Motorola.
you would be better served, to determine what frequencies you want and then pay a certified Motorola dealer who has the software to do the work for you.
Dec 05, 2016 | Radio Communications
DECODING MODEL NUMBER/FREQUENCY RANGE
This is the model number for a UHF Motorola CP185. Specifically, 16-Channel, 4W Model 435-480 MHz. The only way to determine the frequencies programmed into the radio is to have the radio read-out by an authorized Motorola dealer or other entity with a subscription to the software, as well as, a radio interface box (RIB) and appropriate cable.
Best regards.
Nov 29, 2013 | Motorola HT1000, MTS2000, MTX8000/9000...
How do I change and select channels and frequencies w my motorola axv5100 two-way radio? Can it communicate with a motorola talk about?
This radio comes with programmed channels and tone codes programmed into it. Should it still be stock the the diagram below is what you will use. The tones programed into are there to prevent someone on the same frequency from interfering with your conversation. It's a way of isolating the frequency. These are adjusted by the A,B,C,D You will know what frequency it is by the channel indicated. As for weather or not it will communicate with a Motorola talk about the answer is no. This radio is a VHF frequency and the talk about is MURS.
Regards, Tony
Channel - Pre-Loaded VHF Frequency (MHz) - Code (Hz)
1 151.6250 67.0 2 151.6250 77.0 3 151.6250 88.5 4 151.6250 179.9 5 151.6250 None 6 151.9550 67.0 7 151.9550 82.5 8 151.9550 94.8 9 151.9550 179.9 10 151.9550 None
Apr 17, 2011 | Motorola AXV5100 2-Way Radio
I have a 1998 Porsche Boxster and I can't figure out how to tune the radio to a specific frequency so I can play my iPhone through the speakers. It only seems to scan to the next available radio station....
There has to be a tune knob or button near the scan button. If it doesn't,,and I don't know why not...try playing the iPhone first then press the scan button and see if it stops on the channel frequency you need. It may pick up the transmission from the iPhone. If you scan first without the iPhone playing it will definitely bypass the channel. Hope this helps.
Feb 16, 2011 | 1998 Porsche Boxster
Is there a way to change the frequency of a specific channel?
FRS & GMRS frequencies have been preset by the governing bodies where these radios are licensed for use. They consist of Ch 1 - 14 for FRS or Family Radios Service (the new "CB" radio) and Ch 15 - 22 for GMRS or General Mobile radio Service. GMRS frequencies may be repeated 5 Mhz higher - the repeater input of channel 22 (462.750 Mhz) may be heard if close to the transmitter on Ch 22, but if a repeater has been set up to repeat signals in range on Ch 22, they would also be heard on 467.750 Mhz. The repeater will likely have one or more of the following: a high vantage point such as a hill or mountain top, may increased output power of up to 50 watts, or have an antenna with gain properties. Any one or combination of any of these benefits, will result in a significantly increased area of coverage.
FRS Frequencies Channel Frequency in MHz 1 462.5625 2 462.5875 3 462.6125 4 462.6375 5 462.6625 6 462.6875 7 462.7125 8 467.5625 9 467.5875 10 467.6125 11 467.6375 12 467.6625 13 467.6875 14 467.7125 15 462.550 16 462.575 17 462.600 18 462.625 19 462.650 20* 462.675* 21 462.700 22 462.725
It is important to note that only Ch 1 - 14 may be used without a license. Transmitting on any of the GMRS frequencies (Ch 15 - 22) shown in red in the chart above, requires an FCC license if used in the U.S.A. Other countries may or may not have laws for licensing the use of any or all these frequencies, so check before transmitting. Modifying an FRS / GMRS radio is a violation of FCC rules and if caught; can result in fines, prison or both.
If you'd like to be able to tune actual frequencies - and not be limited to specific channels, you ought to look into amateur ("ham") radio. While not in the FRS or GMRS bands, there are literally hundreds of thousands of frequencies to use once licensed. The ARRL (American Radio Relay League) has a great deal of info about ham radio.
I hope this helps & good luck! Please rate my reply - thanks!
Feb 03, 2011 | Motorola TalkAbout T5530 2-Way Radio
Frequency range
The T5720 has
- 7 GMRS/FRS 1 watt Channels
- 7 FRS 1/2 watt Channels
- 8 GMRS 1 watt Channels
All of these frequencies are between 462-467 MHz. There is a list of the specific frequencies assigned to each channel on page 19 of the user guide. Here is a link http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Jun 16, 2010 | Motorola Talkabout T5720 (7 Channels)...
Choosing the right frequencies for Uniden GMR1058-2CKB
Hello huko,
I see from your profile that you are in Bulgaria. Assuming that you are using the European PMR446 version of the Uniden radio in question, the channels / frequencies should be;
1 - 446.00625 MHz
2 - 446.01875 MHz
3 - 446.03125 MHz
4 - 446.04375 MHz
5 - 446.05625 MHz
6 - 446.06875 MHz
7 - 446.08125 MHz
8 - 446.09375 MHz
So, to operate on 446.09375 MHz you would chose channel 8.
If your radio has more then 8 channels, then you may have the U.S. version of the radio which operates on a different set of frequencies and does not have a channel that corresponds to 446.09375 MHz.
Best Regards,
Ken
Go Ahead. Use Us.
Mar 14, 2008 | Uniden GMR1058-2CK (7 Channels) 2-Way...
AXU4100 Manual or help
On a Motorola AXU Series (including the 4100):
1. To unlock, press the “D” button for about a second or until the circle is gone. The circle with the line thru is the keyboard lock indicator;
2. To change channel, you need to press either the arrow left or right in Normal Mode;
3. To change PL (assigned to a channel), don’t think this can be done by the user
4. To change Ch. 1 from 464.500 MHz (PL-67.0) to 463.525 (PL-136.5), don’t think this can also be done by the user.
Even the built-in Programming Mode Parameters do not have this option to change assigned frequencies and PLs. An external programming software using a PC may or may not allow this.
These radios came pre-loaded with its channels assigned with specific frequencies/PLs. As used in a Motorola AXU411, they are:
Channel Frequency PL
1 464.500 67.0
2 464.500 77.0
3 464.500 88.5
4 464.500 179.9
5 464.500 None
6 464.550 67.0
7 464.550 82.5
8 464.550 94.8
9 464.550 179.9
10 464.550 None
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 24, 2007 | Motorola AXU4100 (10 Channels) 2-Way Radio
Radio frequency fades after few seconds
your headset wires are the antenna of your phone... be sure to let it loose freely to avoid the frequency fading... dont fold it...
Oct 27, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Motorola Talkabout T5820 (14 Channels) 2-Way Radio Logo
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
