Philips 3330H DVD recorder: "BLOCKED" is displayed when any attempt is made to eject disk. Disk plays OK, HDD and tuner work OK, only problem is disk is stuck in machine.
SOURCE: DVD RW stucked - stall the whole system.
Hi, I found this site today cos I had a similar problem. To cut a long story short I found a slot on the bottom of the machine, below the disc tray, that has a white lever in it. After removing the power source I moved the lever to the side and the tray opened manually so I could remove the disc. It seems It was a duff DVDR as other discs now work fine. Good luck !
Posted on Apr 01, 2008
Hi all.
I tried the stop & eject on my 3460h but didnt work. However the manual option cured it. It must be a dodgy disc as i tried to play it again but the same happened again. Scrapped the disc.
Posted on Apr 06, 2008
  • 185 Answers
SOURCE: DVD recorder continually stuck on a loop trying to read disk.
Hi again
I am so pleased to hear that you have restored the DMR E55 and for taking the trouble to let me know. It's always satisfying to achieve something like that and I guess you'll get even more pleasure from using it now than you did before. They are good machines and well worth the effort to keep them going.
Thanks again and kind regards
Posted on Feb 01, 2009
  • 371 Answers
SOURCE: Won't recognise DVD disk.
Your system needs a portion of the HDD to swap and stream for the purpose of playing and recording DVDs while CDs are small enough in their data size to play without the minimal size of the space left on your HDD which should be backed up and then erased to give you that brand new feeling.
Try it and get back to me with any problems.
Thanks for asking.
Please Rate.
Posted on Apr 22, 2009
SOURCE: phillips 33805 dvd recorder showing blocked
Ok here is a fix that worked for me. I don't know how long it will last and it's only a partial fix but my unit wouldn't open or shut and I'd come close to throwing it out of the window. Now it seems ok.
Basically the problem lies in the fact that the DVD unit is cheap and nasty in these machines. It is made of poor quality plastic and the mechanism for raising DVDs into place relies on just plastic pegs running down plastic grooved. There are no bearings and no low friction materials. As a result, the mechanism motor is too weak and the unit fails in two ways. 1) It doesn't close the drawer enough to allow the spindle to pass through the centre of the DVD and 2) When the DVD is in place, the motor doesn't have enough power to separate the magnets that hold the spindle to the locking disk above the DVD (sorry if I don't know the correct names for the parts).
The solution to the first problem is to lightly grease the tracks with a silicon grease but MAKE SURE YOU DON'T GET GREASE ON THE DRIVE belt. This is at best a partial fix... I still occasionally have to help my drawer go all the way in with a gentle push.
The result to the second problem is weaken the magnet.
Here's how.
1.Unplug and remove the casing of the unit. First tip is remember where every screw goes... there are a dozen different types.
2. The DVD unit is a black plastic box with a white wheel on the top. Remove the 2 cm wide metal frame that goes over the front (screws in base and in the PCB boards next to the on/off switch and eject button. Again keep an eye on the screws.
3. Remove the two screws on the plastic lid to the front of the DVD unit. There are two black tabs on the lid that you will have to push with a screwdriver to click it out. You will now see the drivespindle and on the lid, you will see the white locking disk.
4. While you have the unit open, clean it and lightly oil it. You can remove the other half of the lid by pulling the two tabs located on the sides. Make sure that you clean and wipe with oil the white mechanism at the front of the unit.
5. Now for the magnets... There are three tabs on the top side of the white locking disk. Gently push these to one side and the two halves will fall apart. Memorise how it goes together.
6. Two washers will drop out. One is a magnet and the other isn't. find out which is the magnet using a screwdriver.
7. Now the silly bit. Throw away the washer that is NOT magnetic and onlly put the magnetic one back. Reassemble. This reduces the grip of the locking disk on the spindle.
I hope this helps. It would appear that Philips have not come to the rescue on this because it would require them to admit that they use shoddy parts. Good Luck - Dave
Posted on Oct 11, 2009
Dvdr 3330h firmwareupdate data disc
Dec 05, 2013 | Philips DVDR3330H DVD Player/HDD Recorder
My recorder DVDR 3330H has the "finalize" in the menu disk but I cannot click on it .
Probably you don't have a DVD+/-R disc inserted but a DVD+/-RW. A rewritable disc can't be finalised and doesn't have to be.
May 28, 2010 | Philips DVDR3330H DVD Player/HDD Recorder
Philips DVP 5992 DVD player disk tray opens without a disk
it think you should open the unit up.get the cd.then try to play it again.
May 18, 2009 | Philips DVP5990 DVD Player
Unknown disk type
Press 'Disc Menu' and wait for 'no disc' to appear on the screen. Eject the tray by pressing the 'open / close' button on front of the recorder. Enter the following numbers very slowly on the remote control ' 0086000 ' Press ' OK ' button on your remote control. Close the tray by pressing ' open / close ' button on the front of the recorder. You can check this has worked by pressing ' 0009 OK ' on your remote after the tray has closed. A display will pop up on screen showing the Region as 0. This means you should be able to play discs from all Regions. If this doesn't work the first time! try again! Hope this helps!!
Jan 24, 2009 | Philips DVDR3380/05 DVD Recorder
3370 H player is 'blocked' cannot eject disk
The eject motor drive may be weak. I find that lubrication does not solve the problem.
Oct 16, 2017 | Televison & Video
Hard Disk recording has sound and picture breakups
Took it to a Philips Service Centre. The hard disk was faulty so it is tobe replaced.
Nov 13, 2008 | Philips DVDR3455/37 DVD Recorder/HDD...
Hi there, try tapping it lightly with your hand just above the tray and then press eject button!! It works everytime with my one!! Hope this helps!!
Nov 01, 2008 | Philips DVDR3380/05 DVD Recorder
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
Dvdr3455/37 stopped working
I had the same problem - and here is how I fixed it.
When it was booting/re-booting I ejected the disk (I needed it out anyway since I assumed the unit was dead.) After ejecting the disk it display "load" on the unit. I read in another message board that this means the unit is looking for the firmware disk. I went to
I followed the instructions to make the "upgrade CD" and inserted into my DVR. My unit then powered up normally. I went ahead and upgraded the software and it did happen again (the re-boot cycle) until I entered the date/time.
Dec 30, 2007 | Philips DVDR3455/37 DVD Recorder/HDD...
Televison & Video Logo
296 people viewed this question
Top Televison & Video Experts
