Question about Philips Magnavox 50ML8105D 50" HDTV DLP TV
My 50" magnavox 50ml8105d/17 making a knocking
  • 760 Answers
It sounds like you have a bad color wheel. If you are handy with electronics, it is a pretty simple fix. If not, I would suggest you take your set to a qualified service center.
Posted on Apr 01, 2011
Magnavox 50 mls105d/17 is making noise
soudns like your color wheel may be going bad or the fan. Fan would be the first to check.
Jan 17, 2013 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
On my 50 inch DLP, there is only about three inches of clear and bright resoulution on the right siade of the screen. The rest is showing the picture dim. I can see the picture but is is dark and dim.
You have some bad capacitors in your set. If you are knowledgeable on electronis components and how they react in a circuit you can check them and replace them yourself. If not have a service tech do the job for you. However if you are electronic savvy then check all the caps in the high voltage section of your set and replace all weak or leaky caps this will fix your problem
Nov 08, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Replaced lamp in magnavox 50ML8105D/17 and now I only get sound for about 10 seconds with no picture then the tv shuts off
I would double check the install of the Lamp and also make sure the Lamp door is closed tightly and secure.
I hope this helps,
Skyassoc
Nov 15, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have a Magnavox 50ML8105D/17 the picture is getting darker
You need a new bulb replacement. The owner manual will even instruct you how to change the bulb.
Oct 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My 50 "Magnavox rear projection has a vary faint picture
If its over 6 years old , sound like the tube are shot , bright/focus together = bad tubes
sorry
Jun 30, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
No picture
Pull the front cover off at the bottom. You will see a panel which has to be removed using a screw driver. Inside you will see the lamp assembly. It is a removable box. The lamp can be changed out by just changing out the connections on the new lamp. Before you pull it though try reducing your picture size to 4:3 it helped us to get a little more life out of our lamp.
Apr 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox HDTV very dim
hi i have a philips 42 pfl5522d and need a new screen can you get me one..
Mar 16, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Philips Magnavox 50ML8105D 50" HDTV DLP TV Logo
520 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
