Question about Maytag EPIC MFW9600S
Flases f 21 code worked fine untill i put new front board in and i cleaned out lines and hose still giving f 21
  • Maytag Master
  • 8,220 Answers
I looked at your tech sheet. As you already know the F-21 on your machine has to do with touchpad not communicating with control. F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/procedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
If you have a new touchpad installed and the harness is fine then the control must be bad.
Posted on Apr 01, 2011
Will not fill after moving DW60EX1
most likely either there is a crimp in the drain hose or water inlet hose. If this is ok then it might just be the way it has been installed in the new place.
Refer page 21 in the manualhttp://manuals.appliancesonline.com.au/dw60cdx2/dw60cdx2_user_guide.pdf
Apr 03, 2014 | Fisher and Paykel Dishwashers
F-21 CODE on maytag 4000 series washer
F21--Long drain
long drain means it is taking to long to drain the water out of the drum.
the pump might be on its way out. running slow faulting.
or it is still is blocked further back.
Nov 14, 2013 | Maytag Washing Machines
Error code 21 appears in display,what does it mean
E21 is slow drain. this means there is something clogging the filter in the hose from the tub to the pump. 1. unplug unit. 2. remove bottom access panel on the front. 3 be ready for water to spill lots of towels you can throw them back in washer when this procedure is done, so don't worry, pack the towels around the hose that comes from the bottom of the tub to the the pump 4 remove the clamp holding the tub to the pump 5 gentle remove the hose this is where you may get wet 6 reach into the hose you will feel a filter (cup like with holes in it) work is out of the hose it will be tuff but it will come out 8 now you have it in your hand clean it out all good 9 put it back it must be there so don't think of leaving it out , you must push it all the way back down until it is set in the grove for the lip of the basket. 10 reassemble the unit
Jun 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Error 21 was on washer, we cleaned out drain then started washer it appeared to be working, but then error message 21 came on again. It is very late so tomorrow morning we will open drain again.
Hello, it can only be dirty filtersomething in the pump drain line blocked up or failed pump. I would check the filter again and if its clean put the drain hose in a bucket see if it drains but chances are you will need a new drain pump. hope this helps please rate my answer thanks
Jun 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code F H will wash for about 4 min then this code starts flasing
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is error code E23 for the Frigidaire Affinty front loading washer
before buying anythings, you have too check the manual too see if you didn't put it in factory test mode by accident. the manual is suppose to be under the top,(two screws on the back)
After that, second thing you have too do, remove the back (six screws) the drain pump is located under the the baril. there is a black rubber tube attached to it. In this tube, there is a basket that keed hard thing away from the pump. In my case, some hair pin pass the basket and block the pump rotor. The computer of the machine told me it was Error E23 but after cleaning, everything work like new!!
So try cleaning it yourself, it is easy even with basic skill. You will need a star screwdriver, a scare-screw driver, pliers.
Remember, better have the machine empty before doing anything, because you'll be working on the DRAIN LINE.
Hope that help someone.
Vincent D.
Jul 09, 2010 | Frigidaire Affinity ATF7000E Front Load...
New Install Went Fine Until E32 Message After Install Cycle - what the heck is an E32 error?
E32 indicates a problem with the pressure sensor. The service manual says to check the wiring (replace if bad), replace the sensor, if problems persist, replace the main circuit board.
There's a copy of the service manual inside the machine - remove two screws in the back and take off the top. The manual includes the error codes and the steps to take.
May 16, 2009 | Electrolux EIFLW55HIW Front Load Washer...
LG Dishwasher LDS5811ST 1E error code
I had a LG certified repairman come out and fix. The electrical wires within the door were melted into the "tar" (sound deafening spray) and one wire actualy sheered. Apparently the drying cycle heats the tar and the wires become embeded and melt into the tar. This is what was causing the error code. After the wire was tested and spliced everything worked great. Long term...The door/electrical harness was replaced by LG.
Oct 08, 2008 | LG 24 in. LDS 5811ST Stainless Steel...
F 21 fault ?? on a kenmore mod 110.47512601
First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Feb 17, 2008 | Kenmore 46462 Front Load Washer
Error messages EFO and E10
It is simple. The wrong soap or too much soap will caused EFO to flash. I overfilled the machine with soap by accident. It started flashing with EFO and I went nuts. What could be wrong with it now?! Too much soap or not the right kind of soap will cause this problem.
Plus, I found a sheet of paper that gives the codes.
This is better than when the strainer plug gets filled up and you have to take the machine apart to clean the little strainer.
Apr 16, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Maytag EPIC MFW9600S Logo
105 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
