Question about Mitsubishi WS-65809 65" Rear Projection Television
I have replaced the IC's and the pico fuses and checked all of the convergence resistors and I am still getting the same bowing only from the top. Is there anything else that could cause this its the exact same as when I had old IC's in.
  • ihughes747 Apr 05, 2011
    So you are saying the bowing can be adjusted out in the advanced convergence menu? I haven't tried that yet did think you could adjust bowing.
    I meant didn't think you could adjust bowing in advanced convergence menu
  • 760 Answers
I would double check the pins on your convergence IC's for any solder bridges and torn traces. Also it is possible that you might have missed a resistor.
Posted on Apr 01, 2011
  • 3 more comments
  • ihughes747 Apr 01, 2011
    I went through every pin and made sure it looked good. I did have once trace that didnt come out good and I created a jumper wire from that pin to the next solder point on the trace and verified continuity from the pin to the following solder point. Also checked for cross solders and it looks good also. Every convergence resistor desoldered from the board and checked with ohm meter they where all very close with in .001 of each other and the new resistors I received in the kit.
  • David Duncan
    David Duncan Apr 01, 2011
    Can you get into the convergence menu and adjust anything at all? Also, are all 3 colors bowing?
    Yes I can move the convergence in all directions and it does seem like all colors are bowed.
  • David Duncan
    David Duncan Apr 05, 2011
    Since you can adjust, you will have to adjust the convergence all the way in one color at a time. It will be time consuming, but worth it.
  • David Duncan
    Yes you can. Unless the IC's are damaged. But since you replaced them and you saw that you can move all 3 colors, you should be good to go. Just take your time. I would start with the green.
Hi there i replaced my hitachi 53uwx10ba convergence IC (2) stk392-120 and now it won't turn on and just flashes at the front panel 7 times, can i get some help pls
Did u check the pico fuse and all those resistors on the tv convergence board to make sure with ones are good resistors which are not good resistors and replace all them resistors too?U didn't do that should get it tested and replaces all those dying resitors.Try website like Tvrepairworld.com look up ur Hitachi tv model what resistors and pico fuse u require to check.
Aug 20, 2011 | Hitachi 53UDX10B 53" Rear Projection...
I replaced my convergence chips in my mitsubishi projection tv, the convergence is still out and does not move at all when I try, also there is still the bow tie - the top and bottom center pull in. Did i...
Hard to say what might be the problem, but I would be checking for the following:
a) verify all fuses (pico fuses) are not blown. They look like yellow, or green resistors typically and should be marked with some sort of "Fxxx" designator
b) Verify resistors around the STK chips are of the right value
c) Verify your soldering connections
d) It is possible the part you installed was defective. Verify you cannot move any color in any direction. (horizontal or vertical)
e) Try to verify if power is getting to the IC - if so, then likely an IC problem. If not, likely a fuse problem.
f) Finally get a schematic and verify the pinout from the STK chip to the red,blue, green connectors to ensure you did not accidently remove a surface mount resistor.
Mar 20, 2011 | Mitsubishi Televison & Video
I have 52" rca/ge itc
replace the 2 convergence STK IC BEFORE replacing the IC make sure that all the pico resistor are not open check the resistance with an multimeter replace any open reading resistor.replace also all bulging capacitors on the convergence section...good luck let me hear how it goes.
Mar 18, 2011 | Televison & Video
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
KP-53HS30 My picture is curved at the top and bottom and the writing is like a shadow of 3's red green and blue
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Mar 28, 2009 | Sony KP-53HS30 53" Rear Projection...
HCM653W color convergence off
Ck low ohm resistors 3.9 omh and pico fuses they look like resistors but they are green or yellow 5amps, 6amps,sometimes after replacing STKs there is bad resistors or open pico fuses.
Dec 22, 2008 | Samsung HCM653W 65" Rear Projection...
Ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
Dec 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
KP-51HW40 Convergence Problem
actually your model should only need two STK392-560 Convergence ICs and six 3.5 amp pico fuses. You can get the replacement ICs and pico fuses at the following link with free installation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Sep 17, 2008 | Sony KP-51HW40 51" Rear Projection...
PT-53WX52
Your TV most likely has a Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 02, 2007 | Panasonic PT-53WX52 53" Rear Projection...
JVC 56wp30 convergence
  • Screen looks 3D
0667c5f.pngSOLUTION
Jul 30, 2007 | JVC AV-56WP30 56" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
