Question about Seagate BlackArmor NAS 110 (ST310005MNA10GRK) 1000 GB Network Storage Server
No server found on your network is the error message i recd while accessing by external black armor harddisk nas 110 Seagate BlackArmor NAS 110 (ST310005MNA10GRK) 1000 GB Network Storage Server
Seagate blackarmor nas 110 is not detected
If its a software prob, just turn off your firewall.
Feb 26, 2013 | Seagate BlackArmor NAS 110...
Seagate nas 220 will not play mp3 files
The file format is dictated by the OS and accessable by software, meaning it needs to associated with a player like Winamp. Try installing a new meida player.
Right clicking the files will also give you the option to assign a program. "Open With." You also need admin rights. This may aslo be the problem, if you are not the owner / administrator.
Dec 31, 2012 | Seagate BlackArmor 220 Network Storage...
Seaget BlackArmor NAS 110 not booting
Sounds like a software problem with your BlackArmor or perhaps a failing drive. You might contact a low cost data recovery service such as http://FreeDataRecovery.us
They perform online data recovery over the internet and also offer do-it-yourself data recovery advice.
Oct 10, 2012 | Seagate BlackArmor NAS 110...
Do I need to power down?
No. Hard rives are for the most part the only moving part on a computer. Failures occur randomly just as flat tires on cars occur randomly. If the drive is going to fail it is normally due to wear or factory defect.
Mar 18, 2012 | Seagate BlackArmor NAS 220 6.0TB Network...
FTP not working on BlackArmor using IE or Windows 7 Explorer Share created, even public access enabled. Details: 200 Switching to ASCII mode 550 Permission denied
Check on BlackArmor Manager that the FTP mode is enabled for the folder you want access to.
You can check it by typing "http://192.168.1.66" in the adress bar on your explorer, enter your login and password ("admin" and "admin" by default), then click
storage -> shares
if "FTP" is disabled, click on the pen (modify) and enable it. don't forget to click "submit" ;-)
Hope it was helpful
Sep 24, 2011 | Seagate BlackArmor NAS 110...
I have HP HDX-18 laptop, Windows 7 Ultimate installed I installed Segate BlackArmor WS 110 on the PC The IPv4 Address :192.168.0.199 IPv4 DNS Server :192.168.0.1 I used: Programs...
I'm assuming the IP address of 192.168.0.199 is actually that of the computer you are using and not that of the Seagate. You need to determine the address of the Seagate, download this: PortScan
Unzip and run it. Start address is 192.168.0.1, end address is 192.168.0.255 (it should automatically detect this). The scan will display a list of all the devices connected to your network and attempt to display what it is. Locate the Seagate and enter its IP in the text box.
Mar 07, 2017 | Seagate BlackArmor NAS 110...
Can the hard drive be replaced by end user?
Most probably, however claim warranty support if you can as opening up the unit will void all warranty.
damnor01
Apr 14, 2011 | Seagate BlackArmor NAS 110...
My Black Armor NAS keep changing its IP address and can't be accessed most of the time on the network. Hw can i fix this
Configure your network's DHCP-server to *ALWAYS* give the *SAME* IP-address to the NAS -- use the (unique) MAC-address of the NAS's network-adapter to assign a "static" or "fixed" IP-address to the NAS.
Jul 27, 2010 | Computers & Internet
I have a belkin N F5D8233-4v3 router with the latest software and I recently bought a black armor NAS 110 network storage and the NAS 110 cant pull an ip from the router when it is connected.
log on to the NAS device and see if it has a static IP embedded. If this doesnt help, try to replace the cable that connects the router and the NAS device. That could help
Thanks
Ranjit
Dec 09, 2009 | Computers & Internet
Seagate BlackArmor NAS 110 (ST310005MNA10GRK) 1000 GB Network Storage Server Logo
684 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
