Question about Edirol V4 Video Mixer With Effectsships Free
I HAVE PROBLEM WITH MANUAL HANDLE NOW I ONLY USE AUTO TAKE .. WITH MY EDIROL V4
  • Edirol Master
  • 5,603 Answers
The potentiometer has probably failed... You can TRY putting a bit of CRC226 which is available at HomeDepot in the electrical dept. into the slot and working it. Use only that product as there are other CRC products there. About $2.70 in a small blue aerosol can. Use the spout, spray into the center and move handle. repeat a few times. If that doesn't' work, replace the pot.
Posted on Apr 01, 2011
Fault on auto mixer
To direct you to a schematic we will need the make and model of the mixer.
May 01, 2016 | Music
Casio - 120 Turns itself off randomly
Casio CDP has Auto Power Off: 30 minutes after last key operation, Auto Power Off can be disabled.
Please read the manual.
Jan 06, 2014 | Casio Music
Headphone jack is too big for my headphones
Get a
Universal 1/8" to 1/4" Headphone Adapter
Mar 21, 2013 | Casio Px700 Digital Piano
Windows 7 64 can not install the driver
Windows 7 64Bit requires signed drivers. Try looking on vendor's website otherwise I am afraid you need to either get a new controller or disable this requirement (not supported by MS)
Jun 07, 2012 | Edirol PCR-M30 32 key USB MIDI Keyboard...
We would like to buy the Edirol V8 video switcher for live internet broadcast. I need to know if this is the correct product for us. We have 3 cameras and a projector going into the switcher and then it...
Dear crane_editor,
For broadcasting the video signal coming from the V-8 over the internet you need to have a computer that is equipped with a composite or S-Video input card. Additionally you might need an audio input as well with the possibility to delay the audio to have a live stream with lipsync audio and video.
Roland has launched a new product recently which is actually designed for live streaming applicatons like this. It's called VR-5 AV Mixer & Recorder. This device has a USB streaming output for easy connecting with a computer. The computer will recognize the VR-5 as a USB audio/video class device (like a webcam) so your setup is ready in minutes.
Further the VR-5 is equipped with an audio mixer (with delay for lip sync), built-in preview screens with touch select, PC VGA input, media player and AV recorder (SD card).
Probably the VR-5 covers all of your needs, without the hassle of difficult configuration of all kinds of separate devices.
Kind regards,
Kees
Sep 22, 2011 | Edirol / Roland V-8 Eight Channel Live...
How can ground the edirol m-100 fx
See the manual!Zou have ground screw next to digital coaxial out!
Jul 25, 2011 | Edirol M100fx (m100-fx) (m100 Fx)
Input has shorted. Cant figure out how to take this amp apart.
There are USUALLY 4 screws in dress washers on the top... AND hidden are two for the handle that also grab the amp. Sometimes there are caps over the ends of the handle thaat have to be snapped off... they can be a pain to get off. I believe the amp portion slides out the back... Thhere is twwo wires under the amp that go through a hole to go to the speaker... be careful they are short and they MAY have a ferrite donut around them... It is usually a fight to get them free and even worse when reassemblling to get them back on... AND they put hot melt glue on the connector in the amp... You have to carefully release that...I have a BX1200 and have had it apart once for repair... Input shorted? You mean the input power or the input audio jack... if the latter, let me guess... somebody tripped over the guitar cable... happens all the time... that is why we loop the cable through the handle to avoid breaking the inout connectors.
I am not sure how you analyzed the input audio connector is shorted... these jacks are JUNK and easily broken. If the input POWER is shorted, or appears to be shorted, it may be deeper than the power supply... USUALLY one of the amp chips is shorted.
Here is the service manual for the BX1200 which should be similar... they may have paralleled another LM3886 to get the 180 watts.
http://elektrotanya.com/behringer_bx1200_sch.zip/download.html
Scroll down to the "Get Manual" link and click on it to download.
Apr 20, 2011 | Behringer Ultrabass Bxl1800 180w 1x12 Bass...
The output is coming out of the wrong side of the headphones (i.e., suppose to present sounds on left, comes out on right headphone)
You will need to reinstall the drivers
If that doesn't work...you will need software that allows you to invert the sound.
Please rate if this helps!
Mar 03, 2011 | Edirol UA-1EX USB Audio Interface
Edirol Midi Keyboard Controller PC-50 Many notes no longer sounding. Can't get into keyboard to check contacts
Well, you have to get into the keyboard. There will be screws or latches that hold the case together.
SOMETIMES screws are hidden beneath stuck on rubber feet.
SOMETIMES plastic latches are where there are slots... have to be careful as they can break if you don't open them right.
WORST are latches along the sides that you have to pry open... knowing where they are is key.
You will probably find that the keys consist of conductive rubber "pills" that are in silicone rubber domes that the keys press against finger-like circuit traces on a board under the keys.
Clean BOTH the pills and the traces with 99% isoprophyl alcohol and a Q-tip.
Dec 11, 2009 | Music
Edirol V4 Video Mixer With Effectsships Free Logo
Top Edirol Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an Edirol Music Expert? Answer questions, earn points and help others
