Question about Vacuums
Gear box yardwork 24"
  • willmcc Apr 07, 2011
    we have crossed lines i s a snow blower gear box thank you william .
  • Vacuums Master
  • 5,370 Answers
If the gear box is blown, it will cost the replacement/ repairing charges.If anything not working in the gearbox the augers would be dead.Many a times gears gets friezed or jammed.It requires oil to free the gears internally. It develops condensation over time and that can cause the contents of the box to freeze.But if gears are worn out or gear teeth are cracked.Then gear box needs to be replaced.------- --------- Thanks.Helpmech,
Posted on Apr 08, 2011
    President:
  • 1,654 Answers
Yes you did. These are one of the worst outdoor tools I have ever seen. Constantly breaking down, batteries don't last either. There are several blogs out there that just beat this company and their product to shreds. These are nothing compared to similar priced tools. I dumped mine and got a black and deckers 24volt. Much better and more durable. Save your money and do not get this repaired if they won't warranty it. Spend your good hard earned money on a company that backs their products and one you can get serviced locally.
Posted on Apr 07, 2011
Self propelled high speed
If by "lever" you mean the step on rocker pedal at the rear of the unit, then we're talking about the same thing. If not, then I have no idea what lever would move to "D" or "I". When the pedal is depressed on one side it puts the drive mechanism into gear, when it's depressed the other side it moves the drive mechanism out of gear. It's about that simple, unless the pedal is broken inside the drive box, then nothing happens either way, usually. The only way to tell if it's really broken is to try it in both directions, if there's no drive in either side then there's a problem in the box. You'll need to take it to a qualified repair shop, not everyone can repair these drive boxes.
Nov 11, 2013 | Kirby G4 Bagged Upright Vacuum
Hoover Elite 300 belt replacement?
Take the broken belt to a vacuum cleaner repair shop to match it up to a replacement.
May 27, 2013 | Vacuums
Yardworks retractable hose reel will not pull out from base
I don't have a solution but the other contributors are a pack of useless ***** and who shouldn't waste people's time with their pathetic mis-spelt answers.
Jun 24, 2012 | Vacuums
We used our hoover carpet cleaner once and the next time we went to use it the brushes no longer turned. I was very careful about cleaning it well after the first use, but checked to make sure that could...
Hello
Either the brushes are not in correctly or there is a lever or slde switch to disable them.
Make sure that lever is in the brushes on position.
Also check that the gears are turning while the brushes are out.
Jun 05, 2011 | Hoover F7452-900 SteamVac Upright Vacuum
I bought the Bissell Heavy Duty in Jan 2009 and now the brush will not rotate. I have gone through all the trouble shooting procedures and it still does not work. Is my vacuum under a one year warranty? If...
if the brush does not rotate when it is in use, chances are the belt is broken. Belts are common to break and should be replaced once a year under normal use. (once a week) and heavier use, more times per year.
If the brush itself is not rotating, meaning you took it out of the machine and it physically does not spin, then you may need to replace the brush with a new one. You can possibly get one at your nearest vacuum repair center.
Good luck.
Nov 19, 2010 | Bissell Vacuums
MY WIFE BOUGHT THIS FOR ME FOR FATHERS DAY GIFT ABOUT ALMOST 2 YEARS NOW OR SO,BUT I HAVE THIS PROBLEM THAT THE BRUSH DOS'NT SPIN ANYMORE EVERYTIME I PUT THE SWITCH ON FOR BRUSH ON,THE HOSES BRUSH SPIN IS...
This unit uses a turbine assy to turn the brushes. The brushes could have something jamming them. Remove the brush unit, it is held on 2 spring hooks 1 on each side. The brush unit is driven thru a 1/4" square post, only one brush is driven and it drives the next then it drives the next etc. If something is jammed in these gears it will stop the entire brush assy. The turbine assy could be bad, but I would check the brush assy first.
Nov 10, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
