Can't lower cooling temp - Heating & Cooling
    Scholar:
  • 133 Answers
Is you indoor fan running? Is the out door unit running? (Condensing Unit) If both are true, is the larger of the two copper lines on the Condensing Unit colder than the smaller one? If not, is the compressor in the Condensing Unit running? The compressor is the big can under the fan in the Condensing Unit. Please reply to this as you may need a service tech. at this point.
Posted on Apr 01, 2011
  • Roger Jelinek Apr 02, 2011
    I can't find a reply to my questions but one thumb means I didn't help you at all. Please let me know where you are at with this problem. I can walk you through almost anything. Thank you for using FizYa. I hope you stay with me.
    Roger
My outside unit isn't running when I switch the thermostat "on".
Outdoor unit won't turn on when switched to on. That is the blower manual on. Selecting cool and lowering set temp lower than actual room temp will bring outdoor unit on.
Aug 14, 2017 | Heating & Cooling
Lowering arcticpro temp.
Find in a manual in advanced setup where you can adjust the maximum and minimum cooling and max min heating. Should be a set point that someone set to where it won't go lower than 76
Jun 05, 2016 | Arcticpro Ypc-07c Faac7 Portable Air...
What makes the cooling fans turn on?
there is a temperature sensor that feeds the ecm(computer)a signal to let it know if the motor requires cooling operation at a predermined temp,which the ecm sends a signal to the cooling fan relay to turn on the cooling fans.when the temp lowers to a predetermined temp the signal is turned off to the ecm and the ecm turns off the signal to the fan relay to turn off the cooling fans.
Sep 18, 2011 | 2000 Pontiac Grand Am GT
Purchased a couple of months ago. No problems with operation or cooling. Does a great job of colling the room and even risidual rooms on that level. Turned unit off while on vacation for one week. Upon...
When the environmental temperature is lower than the set range, the display will indicate "LO".
Lowering the temperature you have it set on, should resolve the problem.
Hope this helped you and thanks for choosing FixYa.
Aug 21, 2011 | Haier CPRB07XC7 Portable Air Conditioner
2002 Jetta 1.8T blew 40A cooling fan fuse - overheated, destroyed 4 way cooling hose connector - replaced all- now it still runs very hot, inside temp reads 190 (but temp is much higher), cooling fans run...
Then replace the thermostat, because if on lower hose not hot and on upper hose scalding hot = antifreeze flow blocked by the thermostat wich remains closed!!!
Thermostat replacing:
Aug 27, 2010 | 2002 Volkswagen Jetta TDI
Can not get temp below 77
Is the thermostat set up for automatic change over from heat to cool? If so, the heat is probably set for 75, you will need to lower the heat setting in order to Lower the cooling. the stat won't let these settings with in 2 degrees of each other so the heating and cooling don't fight each other.
Aug 25, 2009 | Heating & Cooling
Can't change temp setting. no response from soft touch buttons for warmer/cooler temp. changed batteries but no difference.
if the stat is in auto changeover from heat to cool you might need to lower the heat temperature setting before you can lower the cooling setting, these need to be 2 to 3 degrees apart and the stat will not let you over lap them.
Aug 15, 2009 | Honeywell CT3200 5-2 Day Electronic...
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
