Question about GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
GE DSS25KSRESS SIde by Side Refrigerator - about 4 years old. Problem with Freezer. It does not consistently hold temperature, every few days the top part warms up and melts ice which drips down to lower part of freezer and refreezes. Also when that happens, water line freezes and items in the lower part of Refrigerator freeze. It appears the circulation fan is not working enough of the time, is there a control sensor unit for that? OR is this a more serious issue here?
  • cgary_5 Apr 02, 2011
    This is not under warranty anymore. We actually took it from a friend that said they were having trouble with it and maybe even suspected an issue with their daughter standing inside once in awhile. Do you think the timer, which you referenced as located in the toe kick area could have been damaged, I may pull that and see if it needs to be replaced?
  • 5,603 Answers
The frost free function is not working consistently causing the coils to coat with ice. The usual cause is a failure of the thermostat for the coils or the heating elements or the timer which is often mounted on the front rail at the toe kick area. Unless you are handy at electrical and have access to appliance parts this is probably not DIY... cost is often $250 which is far less than new refrigerator. Also check if your warranty might be valid or any maintenance contract.
Posted on Apr 01, 2011
  • Fred Yearian Apr 02, 2011
    The timer is usually fairly well protected and mounted on the backside of the rail at the toe kick. They often have a shaft that is plastic showing... often about 3/8 inch diameter witha ratchet like face. If you can find this, watch it for several hours aand see if it turns. It will usually be once per 24 hours. If it doesn't, feel if it is slightly warm indicating the motor is getting power. Since there are three major components involved, the timer, the thermostat that senses the coils have been warmed where the ice is evaporated, and the heaters themselves. One thing to check is that the DRAIN that drains into a pan is free. If the water melted puddled under the freezer coils it might re-frost faster. It should drain to a pan underneath and evaporate from there.
GE Profile Arctic Side x Side Refrigerator PSC23MGNA
if you were able to do the test... check the compressor unit, also the do check on the electrical relay of the ref.
Jul 01, 2008 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
I have a GE Profile Side by Side TPX21PR/Tpx21BR. The freezer is not freezing ice cream or even bread, but the meat seems fine. There has been a loud noise emanating from the unit for over a year.
Kindly provide few more details so that i could provide more appropriate solution to your problem :-
1. How old is the unit?
2. Kindly hear the noise - Is it from the freezer section or upper back or lower back of the refrigerator?
3. Do you hear the compressor running?
4. Any problem with temperature in lower section or is it limited to freezer section?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 21, 2011 | GE Refrigerators
My GE side by side refrigerator model PSC25MSWA has a problem. The temperature in the freezer and the refrigerator don't stay at the settings that I want (0/37) and flcutuate from day to day. Sometimes...
HI no these techs are wrong, you need to change the motherboard, gas/freon leaks are less than 2% of failures on GE refrigerators. Change the board and you will be fine.
Sean
Mar 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display
can be illuminated by pressing an adjacent temperature adjustment button. When both displays are
illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all
4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and
freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button
will increment the numbers up and the WARMER temperature adjustment button will increment the
numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in
the refrigerator display. When a test code has been entered, the displays will flash to confirm the test.
Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will
increment the numbers down and the WARMER temperature adjustment button will increment the
numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the
freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test
code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. GSS manual
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side freezer/refrigerator. The
When you say "The items in the freezer are cold with some ice on them. I have tried emptying the ice tray, but that does not help." Is there literally ice from the ice bucket dripping on the food and refreezing, or is there a layer of frost on the food? the noise you are hearing is most likely due to the evaporator fan motor running at alternating low and high speeds. This is a variable speed motor, but there could be quite a few reasons why the motor is not rotating at regulated speeds. the fan motor itself, a faulty thermistor, you could also have an issue with your main control board, or least of all a wiring issue.
You would be wise to have it inspected by a reliable refrigerator repair service, to at least determine what the problem is for certain.
Mar 31, 2010 | GE 13.7 cu. ft. General Electric Upright...
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
GE PSW26M Artica Cooling and Ice Maker Problems
on the back of the frig is a small rectangle panel. inside that panel is the motherboard that controls the whole refrigerator. thoughs boards have been nothing but trouble. one of the problems it causes when it goes bad is the problem your having. replace the board to fix it
Nov 29, 2007 | GE Profile PSW26P Stainless Steel Side by...
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Profile is 1.5 yrs old and I have the same problem. I came home to find all my food spoiled! It seems many GEs have had this problem, I agree GE should do something, there are expensive units.
Jun 17, 2007 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
GE Profile 25.6 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
138 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
