The laptop was dropped, now the screen opens with two identical desktop images side by side, with a dark line between the two, Help
  • 2,098 Answers
Hi vi_sund,
This was caused by loose connection from the the LCD controller board and or the LCD display cable. If you can take it apart pull-out this cables then re-insert. You may watch this video for more info...
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 01, 2011
Dell insiron1505 monitor goes dark
Could be backlighting, loose ribbon cable, tiny switch that turns the monitor on and off when lid is opened and closed. Even a driver issue. Can you see a "ghost image" of your desktop in a very bright light? Has the laptop beed jarred, dropped, fallen over...etc.?
Nov 09, 2012 | Dell Inspiron 15R Laptop
Problem regarding laptop screen.
Pehaps the monitor is going or the drivers need to be replace? How old is the laptop, has there been any damage done, drop, jared? I have aHP DV 9320 and I knocked it over on a carpeted floor and the screen went out a ribbon cable jared loose, I open the monitor and fixed it. It could be as simple as adjusting your desktop to "full, Stretch,etc." in Desktop Background settings.
Oct 29, 2012 | HP Computers & Internet
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
VERY Dim screen after a drop
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
There is a dark patch on my screen and it comes on all the pictures
Your camera is having horizontal lines due to a faulty CCD, and not due to other problems.
Just tap on the side of the camera at times the horizontal lines will disappear.
If the problem is due to your dropping the camera, you might be out of luck.
If you have not dropped your camera and still facing this problem, then contact service people to replace the CCD imager in your camera .
Hope this helps .
Jan 30, 2010 | Kodak EasyShare C633 Digital Camera
Pink vertical line in acer aspire 4736z
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 09, 2009 | Compaq Presario M2000 Notebook
The camera is developing dark areas around the edge of the pictures on 2 different sides. you can see these dark spots on the viewfinder and on the pictures. what is causing this?
If your lens is clean.
The dark spots maybe your image pickup sensor going out. Try going into the menu to tools select pixel mapping see if that helps it will look at all your pixels and determine if they are bad & try to compensate.
Hope it helps. Good Luck! please let me Know if this works or if you need more help.
Mar 11, 2009 | Nikon Coolpix 4800 Digital Camera
Dark screen with dull image in background
You may need to check your desktop image for your monitor and change it to something lighter
The external monitor usually uses your computer's default and not ncessarily the one from your laptop monitor
Without taking it apart myself, it could be some wiring from the laptop to the screen
Dec 13, 2008 | Computers & Internet
Mutiple screens after startup
From your description it sounds like you've got an image set as your desktop background and it set to "tile" mode. If this is the case you can change it as follows: -Click on Start, settings, control panel -Double left click on Display. -Click on the Desktop tab -If you want to remove the background image just highlight None from the list of backgrounds. If you just want to display one, small image click on pull down arrow to the left of the Position field (bottom right hand section) and select Center. Use Stretch to make the picture fill the entire field. If this solves your issue please don't forget to rate the posting, otherwise give us some additional details as to the exact nature of your issue.
Jan 29, 2007 | Dell Inspiron 6000 Notebook
DARK HORIZON AREA AT TOP OF SCREEN
not sure but you could have a bad color wheel i would suggest a service call from your local shop
Jun 07, 2006 | Samsung DLP HL-P5663W 56" TV
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
