How do I set a casio ms 80s to recognize the percent sign function. I believe the percent button says set/%. What I would like to do is enter a number, subtract percent and get my answer minus the percent. Can I do this with this calculator? Or do I have to multiply get my answer and then subtract to arrive at my percent?
SOURCE: HELP WITH SIMPLE ADDING, SUBRACTING AND MULTIPLYING
I love that old, little calculator, the TI-1795+ (not the new one, SV).
Does anyone know where to get any more of these. I'd buy a few,
but they are probably out of production. I've had my three for years
and years and years. They still work fine.
Posted on Jan 02, 2009
SOURCE: CASIO ms-7TV
To change the task number you must press and hold % (rate set) for 3 to 5 seconds, should appear tax XX %, now type your tax number and press % again and AC. To test type "100" press TAX + and the result should be 110, if your tax rate is 10% for example.
Posted on Aug 13, 2010
SOURCE: Need to change tax rate
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Posted on Dec 09, 2010
  • 8068 Answers
SOURCE: We are trying to add, subtract, multiply, and
This post is rather exhaustive as regards the matrix capabilities of the calculator. So if the post recalls things you already know, please skip them. Matrix multiplication is at the end. As to division of matrices, I do not believe that this operation exits.
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matrices, at the end.)
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2: D A T A] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
To raise a matrix to a power 2 [x2], cube [x3]
To obtain inverse of a SQUARE MatA already defined MatA[x^-1]. The key [x^-1] is the x to the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Dimensions of matrices involved in operations must match. Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular numbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrix by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Posted on May 10, 2011
  • 266 Answers
SOURCE: can not reset calculator. Keep getting + sign when press enter
If the TI-84 does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Posted on Feb 24, 2013
Minus 20% of 175.00 using the percentage key
On most Casio calculators you must type: '175 x 20 % -' (and '+' is for adding a percentage)
Feb 18, 2015 | Casio MS-80S Calculator
How do I calculate the precentage
Percent simply means "out of 100", so one half (ie 0.5) needs to be multiplied by 100 to give 50% (for example).
Your calculator may have a percentage function (usually on the equals sign but you will need to refer to the instructions to check how it works.
Nov 22, 2011 | Casio MS-80TV Scientific Calculator
How do you do fractions on a Casio fx300 ms?
You have a button marked [a b/c].
To type in a mixed fraction, 2 and 5/ 17
2 [a b/c] 5 [a b/c]17 [=].
To enter an improper fraction use the division sign or press the [a b/c] key after the numerator.
Jun 28, 2011 | Casio FX300S-TP Calculator
How to change tax rate on MS-8TV calculator
Press AC first, then hold down the RATE SET % button for 2 seconds, then input the rate and press RATE SET % button again
And you should be away :-)
Aug 12, 2009 | Casio Office Equipment & Supplies
My calculator will not let me add or subtract percentages.
I have a Casino MS-80S and yea, the percentage works different. As example to take 100 and subtract 10%, this is what I do: 100 X 10% - and then I get the answer 90 after I press the minus key. To add the percentage instead, 100 X 10% + will give me an answer of 110, after I press the plus key.
Apr 04, 2009 | Casio HR8TM Calculator
My casio MS-TE caculates 100+5%=105.26315,not
From CASIO FAQS:
Why do I get the wrong answer when doing a percent calculation?
Make sure that you are following the correct procedure.
Adding 10%: 200 [×] 10 [%] [+]
Subtract 10%: 200 [×] 10 [%] [-]
Mar 26, 2009 | Casio MS-80TE Calculator
Casio fx-9860g ............ how to do percent operation
[OPTN][LIST] scroll right till you find %. Press the function first then the number. It gives you the percent.
Hope it helps.
Aug 29, 2008 | Casio FX-9860G Graphic Calculator
CASIO ms-7TV
Jul 21, 2008 | Office Equipment & Supplies
Casio MS-120TE tax rate
Found this on the casio site worked fine on my ms-120TE
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds until set and a 0 is displayed
3. Press [TAX+]
5. Press [SET/%]
this is the link:- http://www.casio.com/support/content/AF64A1AC-193D-4650-A9A9-98BB6FE26CFE
Dec 05, 2007 | Casio fx-300ES Calculator
Casio calculator MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Jun 11, 2007 | Casio MS-80TV Scientific Calculator
80 people viewed this question
k24674
jasbo
jasbo
