Question about Dryers
I have a Admiral Electric Dryer -Super Capacity, Stainless Steel Panel. How do I get the belt off to replace.
  • Dryers Master
  • 8,220 Answers
Interesting question. You know in recent years Admiral have been acquired by Whirlpool. Several tried and true base models have the Admiral logo on them now so it would be a guess as to which model you have. Why not post a follow up and add the model number ?
Posted on Apr 01, 2011
Noise of tromnel de dryer
probably a balancer spring came off, or belt defective
Jan 31, 2016 | Blomberg DV17542 DV17542 24" Front-Load...
How do you open the Frigidaire affinity dryer bc i think the belt is broken
If the belt is broken dryer will not tumble, you can turn drum and should be resistance to turn, if turns easy then belt is broken. This is a difficult repair. If you can't see how to open dryer you won't be able to replace belt.
Aug 30, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
How to change belt?
Make sure power is off, take off back panel, slacken belt tensioner or motor, replace belt. It should be that easy.
Aug 21, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Samsung dryer lint
check inside the cabinet for lint build up?
Jul 09, 2014 | Samsung DV50F9A6GVW 27" Gas Dryer with 7.4...
Model 10.87729701
If the dryer comes on and sounds like the motor is running, your most likely failure would be a broken belt. This is replaced by removing the top first, then the toe kick, and the front door and panel. Pleazer Appliance...
Apr 07, 2014 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
Samsung dryer will not start or light up.
Check to ensure that you have power to the unit. If you are sure, the next step would be to check the thermal fuse, as it is the most likely candidate. If you take the back panel off of the dryer, you'll see a small (about 1") piece of white plastic with two wires clipped to it. The plastic piece is the thermal fuse. You can try to jump the wires (bypassing the fuse) to test the unit. If that is the issue, you can get a new thermal fuse on Amazon.com for under $5.
I hope this helps. Good luck.
Oct 23, 2013 | Samsung DV50F9A6EVW 27" Electric Dryer...
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Dryers Logo
146 people viewed this question
Top Dryers Experts
