Question about Kodak Cameras
My C 743 does not see the SD card.The card is good and is used in another C 743. Have I messed up a menu setting or is this a camera problem?
    Problem Solver:
  • 6 Answers
the kodak C743 can only take upto 8gb SDHC card , if you have a 16 / 32 / 64 & 128gb card these will not work
try upgrading the firmware from the website by this method
  1. Visit the EASYSHARE Software page and download the latest version of software.
  2. Connect the camera to your computer using a USB cable.
    NOTE: The first time you connect your camera to your computer, Sync and Transfer Setup or Sync and Transfer Assistant prompts appear on the screen. Follow the prompts to set up the camera as a device in the software.
  3. Remove the memory card from the camera.
  4. Turn on the camera.
  5. Start EASYSHARE Software.
  6. Select Tools > Sync and Transfer Manager.
  7. Select your device from the list in the left column, and then select the Info tab.
  8. Click Update Firmware, and go to the location where you downloaded the firmware file.
  9. Click Open to copy the file from your computer to the internal memory on the camera.
  10. Turn off the camera, and then disconnect the USB cable from the camera.
  11. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  12. Turn off the camera, and then turn it back on again.
good luck
Posted on Apr 01, 2011
Can i slot in 8gb sdcard(KINGSTON) in C743 without upgrading the firmware,does it works?
Posted on Nov 30, 2011
Q1: Camera: How do I remove the 'Video" setting? Q2: Camera: How do I transfer photo from camera to computer? I know; not the brightest bulb. Thanks
You manipulate and configure all camera settings from the menu.
1. For the video settings, scroll through the menu and you'll find what you you are looking for there.
2. To transfer photo to your computer, various options are available.
If your camera came with a CD (driver), install that on your computer, than connect camera to computer, using the usb chord that came with the camera. Switch on camera and you should access the SD card from the My Computer menu.
Another way is to take out the SD card and plug it to the computer by an card reader or from most Note Book computers, a SD card slot built into the sides somewhere. to access the SD Card, you open My Computer and double click on the SD card icon, open the varoius folders in there to find you photos.
Aug 14, 2014 | Cameras
Will using a SD card from another camera mess up my Canon? Seems ever since I borrowed a SD card my camera has been totally messed up.
As long as it is the right card for your camera you shouldn't have a problem. Try removing it and installing a smaller card, (make sure you power down the Camera 1st).
Dec 29, 2013 | Canon EOS 500D / Digital Rebel T1i Digital...
How do I change coolpix s52 to change from internal memory to sd card?
Try formatting the SD memory card using the camera's Menu setting.
May 04, 2012 | Nikon COOLPIX S52 Digital Camera
Where can I get a memorty card SD 128 MB for my Kodak Easy Share C 743? Can I also use a larger memory card such as 2 GB or 4 Mb? A. N. sparklersconc@yahoo.com
You can use SD cards up to 2GB in size. You cannot use SDHC cards bigger than 2GB. You should be able to get SD cards at any office supply or electronics store. You could probably even find them in most supermarkets and drug stores, though they might cost a little more.
Mar 08, 2010 | Kodak EasyShare C743 Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    Megapixels on camera needs to be reset?
    You can check the user manual to change again the resolution settings, or just reset the camera to the factory settings through the menu settings (last and bottom setting option).
    Best regards,
    May 28, 2009 | Canon PowerShot S3 IS Digital Camera
    "please insert memory card in GZ-MG130U CAMACORDER
    Hi there.
    The hard drive will be full so you will need to transfer all your videos to your PC then format the hard drive in the camera's menu, make sure the SD card is removed before you format it.
    Good luck and thanks for using FixYa!!
    Mar 16, 2009 | JVC GZ-MG130U Camcorder
    Finepix s700 says memory full and wont take more pictures with sd
    i know this is late, but my camera had the same problem.
    1. If you go in the setup menu.
    2. Push the right button once and scroll down to the menu that says format.
    3. It will ask you if you want to erase all data.
    4. Select No and everything should be fine.
    Feb 20, 2009 | Fuji FinePix S700 Digital Camera
    BenQ C850 Switch from internal memory to sd card?
    Try other SD card. 99.99% sure that the card is not good. Borrow your card to someone to check your card with his camera,or Format the card from C850 Menu.
    Jan 30, 2009 | BenQ DC E600 Digital Camera
    I didn't have sim card in the camera when i took photos now
    I recently noticed a mini SD memory card in my cellphone and even though there was data on the chip which I had put there using the SD adapter and my laptop none of the data was viewable on the cellph screen. I went ahead with the Format command on the cellph. It erases my data but I believe I will now be able to store multimedia to the SIM as the Good Lord intended.
    Dec 10, 2008 | Samsung Digimax D53 Digital Camera
    Cameras Logo
    69 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Greg Cann
    Greg Cann
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
