Question about Karcher Garden
My three year old Karcher power washer has suddenly started behaving as if it has lost its power. There is also an intermittent motor noise when I release the trigger. When I press the trigger again the motor noise is constant and normal. Can you help me please?
    Problem Solver:
  • 9 Answers
This sounds like it had water left in it and it froze over the winter. The motot turning on and off signals a water leak on the output side of the pump. You may have a cracked pump housing. Locate the pump and make sure nothing is leaking in that area when under pressure. looh for fine hairline cracks.
Posted on Apr 01, 2011
Hi, My karcher 5.86 has suddenly stopped working. No power/ noise from washer when power is switched on. Fuse & source is obviously fine. Im going to obtain relevant torx screwdriver this week to open...
If its not the fuse in the plug it might be the on/off switch. I would check switch for continuity with a multimeter to rule it out first.
Feb 01, 2015 | Karcher Garden
Karcher K2.94 intermittent pumping and buzzing
try the machine with the lance removed from the gun.
buzzing is usually the noise made by the motor when it cant turn. if the pump start to pruduce pressure but the pressure builds up too high then the motor will stop turning... faulty lance or faulty spill valve (dump valve)
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Aug 05, 2013 | Garden
Karcher K2.54M loss of all pressure
I have seen it before where the little plastic pistons overheat and melt. The unit still runs but with no pressure. I would pull the pump apart and check the pistons.
Sep 03, 2012 | Dishwashers
When i switch my karcher on the motor makes o noise and does not turn
This sounds like you may need a new capacitor. It is not a costly part to get. What the capacitor does is "jump starts" the motor so if it broken the motor will not start.
A test you can do is if you take off the front caseand then set the machine up as if you were going to use it. then when you turn on the machine quickly push the fan blade of the motor with a flat headed screw driver. If this makes the machine start to work, then you know that you need a new capacitor.
Just be carefull when doing the test.
Please remember to thumbs up :)
Apr 03, 2011 | Karcher K2.26 Electric Power Washer
I own a karcher KB 4040 which is about three years old. It has begun loosing pressure as a result of a leak within the motor/pump area. I'm loosing as much water via the pump as goes throught the nozzle....
England (UK)
Home & Garden Helpline: 01295 752200
Karcher USA telephone number
303.738.2400
If you call which ever country you are in telephone number they should be able to guide you to the nearest service center.
Jan 11, 2011 | Karcher Garden
My Karcher pulses when on standby,stops when i use the trigger,but it also seems to have lost pressure.Is less than 6 months old but have lost receipt!
Is there a leak from the bottom ?
If so Problem, the leak is from the seam of the Manifold housing. There is a small crack in the seam. A design weakness.. A New Manifold Complete Replacement approx. $61.03.
If not you may replace the Pump Manifold Housing from Karcher, or locate a local Karcher Service Center.
If under 1 year old, and you can find a receipt,Karcher will replace the entire Pressure Washer under warranty.
May 03, 2010 | Karcher K 5.85 M Electric Pressure Washer
Karcher K2.91M nlets water in and out but won't
wot like a buzzing noise if so try and turn the fan at the rear of the motor if you can do this it is more than likley the capacitor
Dec 04, 2009 | Karcher K2.26 Electric Power Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
702 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
