I am looking for a wire diagram for Lennox rooftop unit GCS3-953-250V-10Y, does anyone have one, or know where to get one? In desperate need of one. Thanks
    Scholar:
  • 133 Answers
Can you supply more information? Lennox has no record of this number in its current records or archives. Please be sure the number is correct. What type of equipment is it? Furnace, AC, IAQ, control?
Posted on Apr 01, 2011
What I need is a 2004 Yamaha 350 wolverine 4x4 Wiring Diagram, anyone got one?
Any chance that Yamaha can provide one? It might be your best source.
Jul 15, 2014 | ATVs
Should there be (3) red wires feeding the rooftop condensor? Is there a pdf of the wiring diagram I can get?
If you're talking about the high voltage wiring, the answer could be yes if it is a 3 phase unit. That means you have 3 separate legs of "hot". Many rooftop units are 230v 3 phase in the US. Single phase would have two hot wires and a ground. Look in the disconnect box. If there are 3 fuses you have a 3 phase unit. If you have 2 fuses, you have a single phase unit. Be careful, you are dealing with very high voltage and very dangerous.
Apr 11, 2011 | Heating & Cooling
Looking for wiring diagram for a duo therm by dometic rooftop air conditiner. I have one small wire unhooked and am not sure where it connects.
There are several models out there. Here are a couple of manuals with wiring diagrams that I believe will help you regardless of the model number. However, if they are unable to help you, let me know the exact model number and we'll search for the wiring diagram. :-)
Link #1
Link #2
May 19, 2010 | Dometic Rooftop RV Air Conditioner
Hello i want to conect a trane condensator 2twb0036a1000ba to a trane evaporator mww536k10raa i need a wiring diagram
Your wiring concerns may be more with the thermostat wiring connections than the condensor connections. if you look inside the cover of the evaporator unit (usually called air handler) there should be a wiring diagram glued to the panel cover. This diagram will show all 3 units (stat,cndsr, airhndlr) and the wiring needed between them. Trane and Lennox are notorious for having the most wiring between components. You also need to be sure the stat is the correct type for the system (i assume this is a heat pump system) and there can be as many as 9 wires from stat to system and 6 wires from inside to outside units. Also, the stat will have a wiring diagram with it that shows most typical system wiring including the wiring between in and out units. Your best bet (if you have no diagram on the unit or with the stat) is to call trane and have their tech division fax a diagram to you. Goodluck,Macgivor
Jan 27, 2010 | Heating & Cooling
I am trying to change Lennox to Honeywell
Just remember what wires went to which terminal. Usually color coded, red =R, white = W, etc, Shouldn't be too hard. Let me know if you run into a problem.
Jan 02, 2010 | Honeywell Electronic Programmable...
FREE ONLINE DOWNLOADS OF WIRING DIAGRAMS
i ned my home hetr and ac wiring diagrams to thral contral
Sep 30, 2009 | 1998 Ford Explorer
Wires not connected on mod# 6759c707
If you google Coleman rooftop air conditioners on your computer, it will give you some dealers that sell that air conditioner and they should be able to help you or tell you where you can get the help.
Apr 03, 2009 | Dometic Rooftop RV Air Conditioner
Wiring Diagram Coleman Electra Heat Mach EL
I need the motor for a mach EL air conditioner. I can not get a model number of the unit or a number off of the motor. Can someone help me. Its about a 1980 built unit.
Mar 29, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
164 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
