Question about ColorSoft AntiARP
When I launch antiarp, it says: "startup failed! error code:2/0 operating system version: windows vista professional service pack 1"
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
Error code 8000ffff when updating vista SP1
To resolve Windows Update error 8000FFFF, try the following steps:
1) Launch REGEDIT
2) Go into HKLM\COMPONENTS, and check if these three values exist under the COMPONENTS key:
PendingXmldentifier
NextQueueEntryIndex
AdvancedInstallersNeedResolving
3) Providing they do exist, back up the Components key, then delete the three above values.
4) Restart the computer, and Windows Update should now be working fine.
Hope this helps. Let me know if you have any questions
Ray
Mar 29, 2011 | Microsoft Windows Vista Home Premium with...
I had Dell Windows XP along time ago. I now have Windows Vista Business and I think it is Service pack 1. I pressed F12 and did diagnosis then it scanned right off the bat it says... "Error Code...
Hi. Error 0146 is pertaining to a failing hard drive. You can still try to reinstall Windows Vista by requesting for a CD from Dell by contacting them.
If they fail to send you a CD or if the error still comes up after reinstalling Vista, then you need to replace your hard drive.
Feb 06, 2011 | Dell Inspiron 1501 Notebook
Hi, I have Purchased Windows Vista Home Basic Edition From Malaysia on 05/03/2009 and activated from Malaysia.Now I am in India and when I re-Installed the same,I can not Activate the Windows! While I am...
This may be due to Windows end of Life policy.
You should try and call Microsoft directly from the phone number which should be displayed.
End of support
Client operating systems Latest update or service pack End of extended support Windows Vista Service Pack 2 April 11, 2017 Windows 7 * Service Pack 1 January 14, 2020 Windows 8 Windows 8.1 January 10, 2023 Windows 10 ** Version 1703 October 14, 2025
Apr 26, 2017 | Microsoft Windows Vista Home Basic Edition
Error code 643
Try this for starters:
http://support.microsoft.com/kb/923100/
Basically, it involves un-installing .NET Framework Version 1.1 Service pack
1.
Then download and use (Run as Administrator) the Windows Installer CleanUp
Utility, and remove all references to .NET Framework Version 1.1 Service
pack 1 (only!).
Then reinstall .NET Framework Version 1.1 Service pack 1:
http://www.microsoft.com/downloads/detai…
Then run Windows Update again, to install KB929729.
Jun 25, 2010 | Microsoft Windows Vista Home Premium with...
Error problem while downloading updates
1. Before doing anything else, write down the .NET Framework versions which
are already installed:
How to determine which versions of the .NET Framework are installed and
whether service packs have been applied
http://support.microsoft.com/kb/318785
2. Now see Resolution Method 2 in http://support.microsoft.com/kb/923100
(ignore the title). After running the appropriate/needed tool, (re)install
all .NET Framework versions manually using the download links on the page.
May 28, 2010 | Microsoft Windows Vista Ultimate Edition
I cannot create my recovery cd... in vista Hp laptop
This is a known issue. Remove the Vista Service Pack 1 and then try creating the Recovery Disc.
After creating the Recovery Disk, reinstall the Vista Service pack 1.
Good Luck!!!!!!!!!!
Oct 11, 2009 | Microsoft Windows Vista Home Premium with...
ERROR IN COUNTER STRIKE GAME IN WINDOWS VISTA
before you run the game right click the icon that launches it and goto properties, goto compatibility tab, check the boxes run in compatibily with xp sp2 and check the box to run as administrator, click apply ok then run the program.
Jan 18, 2009 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
302 people viewed this question
Top ColorSoft Computers & Internet Experts
David Payne
David Payne
Are you a ColorSoft Computer and Internet Expert? Answer questions, earn points and help others
