Question about Creative Labs WebCam Live!
How do i find webcam settings on my asus computer
ASUS UX32VD Zenbook Webcam stopped working
i got the same problem with my new UX32VD.
the camera worked properly for the first week but after that suddenly it's stop working.
any solution?
Sep 05, 2012 | ASUS UX32VD-DB71 Zenbook 13.3" Ultrabook...
My webcam broadcasts upside down on my asus k501
WEBcam Image Settings
Check the WEcam settings. Most WEBcam have a setting toinvert and mirror the image
Nov 11, 2011 | ASUS K50IJ-C1 Notebook
My Asus K51ac web cam USB2.0 1.3M UVC WebCam is showing an upside down image... How can I invert the camera in the holder... Thanks
Basically this should only be a proper driver installation/re-installation. Or you may try the below options
A) Look for the snp2uvc.inf file. Open it with notepad. Look for the entry... HKR, DefaultSettings,Flip,0x00010001,0 - and - HKR,Settings,Flip,0x00010001,0 Change the last digit (zero) to a "1". Save the file and re-install your driver manually from the device manager. You need to choose the driver. Reboot and your video should be now in the correct orientation.
B) Inside the ASUS drivers folder there should be a software called tsnp2std.exe. Open your camera then run this application. An icon on the system tray will appear. Click on it and select Open Property Page. There you should be able to configure the setting.
C) Download the latest webcam driver for your Asus. But first, you need to know what driver you need. There are free software that detects makers of the webcam installed on your computer for proper downloading of your needed driver.
Jul 12, 2011 | Computers & Internet
My webcam is upside down.It is an asus laptop.How can i rotate the picture
Usually you can get to this settings by going to Start>Control Panel>Scanners and Cameras, finding your webcam, right clicking and going to Properties. The setting should be somewhere in there. If not, look for some form of webcam software that might've come preinstalled on the computer and trying that.
Jun 16, 2011 | ASUS K52FA2B Business Laptop
Not work my webcam on my asus n53jq-xr1. the
Shutdown the computer and disconnect webcam. Restart computer then after full boot, attach webcam and test to see if webcam works. If this does not solve the problem restart the computer with webcam attached. If this does not solve the problem then the webcam may be broken. If this is an internal webcam I recommend contacting the manufacturer.
Mar 22, 2011 | ASUS N53JQ-XT1 Laptop Computer - Intel...
Hi there - my webcam is not recognised on my computer anymore - can you please direct me to a driver download that is not a zip file, and also - my laptop no longer reads my phone as a USB device nor does...
ok shanthi...goto control panel> device manager > check for the status of usb drivers.... you can double click on usb to check for the status....if your usb status is working properly then try to install the driver for your webcam...
if your usb status is not working, then first install the usb driver...
Apr 04, 2010 | ASUS F5R-AP038A Notebook
I have just bought my Asus notebook and I want to start using my built in webcam with friends, but I don't know where and how to start.
see if there's a asus lifeframe software installed in your notebook. i have the same notebook and whenever i want to use the built in webcam i use lifeframe.
in case you don't have try downloading it.
http://asus-lifeframe.software.informer.com/
Dec 03, 2009 | ASUS Eee PC 1000H Laptop
My built in webcam for my asus eeepc 1000haxp does not work. this is a new computer
simple Restore Factory Settings or Go to Control Panel and Activate the Webcam either YES/ON.
Nov 17, 2009 | ASUS Eee PC 1000H Laptop
Asus X71SL laptop - webcam issue
Go to the Camera Assistant Software on your computer, then go to Properties, then click on one Flip Vertical Arrow Twice then you should be all set.
Jul 02, 2009 | ASUS X71SL-B2 Laptop
Creative Labs WebCam Live! Logo
56 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
