Question about Microsoft Windows XP Professional
There is no sound coming from my computer though the volume control is right?
    Guru:
  • 433 Answers
No sound mean:
1- speaker is bad
2- entrance sound is bad
3- driver is bad ( re-nstall)
4-windows had a damged files (re- install)
5- sound ic control is damaged ( need out pci/ usb sound card )
6- tow jumper in mother board are take off
best regardes
Posted on Apr 01, 2011
Speakers were working,then i pressed something to see if was gonna sound different and now i cant find my way back to what it was...sound is coming from the computer to the tv,,but external speakers have...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope it helps
Sep 22, 2011 | Logitech X-230 Computer Speakers
No sound even though speakers are already plugged in.
also
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 30, 2011 | Computers & Internet
My sound card is not working though the drivers are installed...reply back superman_cowboy66@yahoo.com
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 16, 2011 | Intel D915GLVG Motherboard
The speakers dont work even though the whole system is plugged correctley the light that should be lite near the volume controller is not working kindly help me in knowing the problem
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers if you dont have a motherboard disk you will need to download the sound drivers
also
if you need more help with this posta reply
hope this helps
Aug 15, 2011 | Creative Labs Inspire T2900 Computer...
Sound comes out of all speakers but the sound from the left speaker plays through the left, right, and sub. instead of just the left speaker. so i have guitars coming out of the sub and bass coming out of...
you might have to select stereo speakers in the drop down list
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
dont forget to vote
Jan 31, 2011 | Kinyo PS-107 Computer Speakers
I attached the G-Max 2000 speakers that were on my XP Gateway to my Windows 7 Gateway. Though the device manager says they're working properly, no sound is coming out.
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 23, 2011 | Gateway GMAX 2100 Computer Speakers
At my computer no sound is comming
Make sure you have speakers switched on and connected to the GREEN socket on the computer. On the right of the taskbare, right click the little speaker Icon and open Volume Control. Make sure volumes are turned up on Volume control and Wave.
Jul 17, 2010 | Dell GX270 P4 256/40/48X/XPP/NONE...
There is no sound coming out of one of my speakers (the one with volume control). The green light underneath comes on and the volume control itself works but no sound comes out of it.
make sure the balance is set properly in the volume controls tab located by right clicking on the speaker icon in the lower right hand side in the startup tool bar
Jul 23, 2009 | JBL CREATURE II Computer Speakers
Low sound coming from soundsticks II
On the right stick, there are two metal pieces at the bottom of the stick. The right one is + for volume up, and the left is - for volume down.
Press the + one a few times with your finger as they are touch activated. Be careful though, as it can get loud very quickly. Play some music and set the computer volume to about half way. Then press the + speaker on the right hand side until you are happy with the volume.
Hope this helps,
Nathan.
Apr 08, 2009 | Harman Kardon Harmon Kardon SoundStick II...
No sound
1. Check your speakers if they're turned on and the volume knob is turned all the way up.
2. Go to Control panel>sound and audio devices.. Click on the "Audio" tab and make sure you see something inside 'default device' under soundplayback that doesnt say microsoft. If it's blank, click the dropdown arrow and choose the non-microsoft option. If it's blank and there's nothing to choose from, go to step 4.
3. Make sure the volume is turned up and not muted in windows. Click on Volume under sound properties and make sure it's not muted. You can also right click the speaker icon on the bottom right hand corner and click 'Open Volume control. all the balance levers should be in the middle and make sure none is muted.
4. Go to Start. Right click 'My Computer'. Click properties>hardware>device manager. If you see a question mark or exclamation mark for an entry that could be related to your audio device, that means you need to reinstall the sound driver.
If this is the case, you can tell me the make and model of the computer so we can look up the correct driver. If the sound card though didnt come with the computer, try reinstalling the cd that came with it.
5. If you dont see a yellow question mark, it's either the sound card inside your computer is not detected (could be loose or defective) or you need to repair windows.
Nov 05, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
