Question about Garden
Single lever moen kitchen tap base of unite moves when swinging tap from side to side. Looking under sink I see a nut attached to a threaded spindle, how do i tighten it up, there is very little space for a wrench, do i need a special tool?
  • 843 Answers
A "basin wrench" is the special tool you need. They are pretty cheap. Any hardware or home improvement store carries them. They might even have them at Walmart. Google images for basin wrench and you will see lots of illustrations, including how to use it. Good luck Please vote if you found this helpful Al K
Posted on Apr 01, 2011
Single moen faucet base plate moves
The mounting nut below has come loose. Have someone hold it in position while you go under and tighten the nut. You may need a basin wrench to do theis.
Oct 28, 2012 | Moen 7065 Vestige Single-Handle Kitchen...
Moen cathedral keeps coming loose and it base moves when you rotate the spout from sink to sink.
tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
May 04, 2011 | Moen Monticello Single-Handle Kitchen...
Do not know what seris of Moen facet I have. The house was built in 1984. I have got water lines off underneath but can not get faucet it self off. Took out the screw and the ring screw and base ring screw...
If it is a single hole faucet, there should be a single nut on the threaded brass piece underneath the sink. You may need a basin wrench to get access to it if you cannot get to it with an adjustable jaw wrench. This nut normally clamps against a U shaped washer that is against the underside of the sink.
Mar 10, 2011 | Moen 87440 Single Handle Kitchen Faucet...
Single handle Spray faucet leaks at it's base, leaking under the kitchen sink
If you still have the receipts from the purchase call Moen directly as they warranty their faucets for life and will send you the replacement parts you need. If you need to purchase replacement parts then you can purchase a Moen single lever repair kit from your local hardware store which should run you around $10. Go the the Moen website and look for your model. They generally have an exploded view of every one of their models that will assist you in dissassembling the tap without any surprises. Reassemble the tap with the new o-rings etc installed and test.
Aug 10, 2010 | Moen 7437 Chateau Single Hole Kitchen...
I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Moen faucet removal
you will have two mounting nuts at each end and two water line to disconnect for removal under the sink on any faucet made
Feb 13, 2010 | Moen 7310 Legend Single-Handle Kitchen...
We are trying to replace our Moen Adler Faucet and we need to know how to remove it.
first off swhut the water off under the sink,if no shut off valves under the sink then shut the main water valve off.next turn the old faucet on to make sure water is off.now get a light and look up and behind the underneath side of sink,disconnect the water supply lines now way up high there is 2 threaded tubes undo the nuts and the old unit will come out.
Jan 11, 2010 | Porter Cable Moen Legend, Single-Handle...
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Can't tighten single handle moehn kitchen faucet
there is supposed to be a nut with a washer under the sink in the center, the metal plate is just for decoration, the nut and washer have to be installed before the sprayer is attached the stem that it connects to has threads on it for the nut your faucet should have came with a long socket made of plastic to install the nut
May 30, 2009 | Moen 87530 Touch Control Single Handle...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
