Question about Tomtom ONE GPS Receiver
Tom tom 3rd edition - no SD card used Have reset 2 or 3 times but will not work at all. Only shows Welcome to TOMTOM one message on blue screen with ! in triangle? Any idea how to get it working or is it junk....?
    Problem Solver:
  • 12 Answers
This issue occurs if the application on the device is corrupted.
To resolve the issue, please uninstall and reinstall the application on the device
Here is the link that has the steps to do so;
http://www.tomtom.com/9091
Posted on Apr 01, 2011
My husbands tomtom IQ routes edition has just frozen - it shows a picture of a world. What can he do to get it back to normal?
I will advice you reset the unit, this might help fix the abnormality with the white screen problem. follow these procedure to reset your tom tom gps.
Make sure your battery is charged before you begin. TomTom suggested allowing your device to charge for at least 2 hours before resetting it. Remove your device's SD card from the card slot.
Find the "Reset" pinhole button on the bottom of the device.
Hold the "Reset" button down for 10 to 15 seconds or until your device resets itself. You will need a flattened paperclip or another small metal object to reach inside the pinhole.
Power the TomTom back on and insert your SD Card. You have now reset your TomTom gps and this should fix the white screen problem.
Take care.
Jul 10, 2010 | Tomtom One IQ Routes GPS Receiver
My tom tom one 3rd edition has frozen how can i get it working please
You can try a hard reset.
By removing the sd card and using i paper clip pushing it into the reset hole on the underside of the unit, push and hold for 15 seconds, Then switch device back on and slot your sd card back in
Apr 24, 2010 | Tomtom ONE GPS Receiver
I have got a binatone a350 but it has got tom tom one edition 3 loaded on it the thing is it comes on but when it gets to last screen all i get is a blue screen and it says NO MAPS. is there a solution...
I have loaded my Binatone B350 With a 128mb SD Card from my old Tom Tom Go which slots in perfect.
When i turn my sat nav on i get a blue screen stating
"WARNING SYSTEM REGISTRY KEY LOST"
The sat nav then reboots itself and goes to the main page
"BINATONE DRIVE LIKE A LOCAL" and then repeats itself to blue screen again. I have taken the card out and still get the blue screen. Any ideas on how to solve this please
Apr 23, 2010 | Tomtom ONE 3rd Edition GPS
My tom tom 1 3rd edition does not find the GPS signal, the message on the screen says "waiting for a valid GPS signal" I have moved and tried to use it in different parts of the country but it doesn't...
Hello :
Reset your GPS and problem will be solved . If resetting didn't solve the problem , then i advice you to replace it with a new one if you still have the guarantee .
Click here to know TomTom GPS resetting .
good luck .
rate please !
Mar 20, 2010 | Tomtom ONE 3rd Edition GPS
Frozen screen
I am not fully up on the third edition but lest see if anything else I have might help you out.
I am going to guess you used tom tom home for the update
If you backed up before the accident then there may be a way to get you up again
If you can get (or have) an sd card reader on your computer then put an empty card in there and format it as fat or fat16
Then tell your tom tom home to RESTORE but point it to your blank sd card.
When it has done throw it in the tom tom and power up this has worked on a couple of other model tom toms.
If you don't have a back up then the only other way is to get a working one and back it up on your machine and do the above.
That's a hit and miss approach though
Aug 22, 2009 | Tomtom ONE 3rd Edition GPS
Screen instructions in wrong language
You could try a HARD RESET
if you look at the bottom there is a small hole for re-setting the tom tom.
It is usually near the SD card slot
Insert the end of a paper clip in there, remove it then switch on.
If this information was useful please click
Aug 13, 2009 | Tomtom ONE 3rd Edition GPS
Tom tom one not turning on used 3 months
I had some problems with the 920. It started to not turn on. The it just died completely. After opening the case and testing the battery. I concluded the battery was dead and Un-chargable.
Which is most likely the case with yours.
Try this first. Then contact customer support.
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card
Unless you are good with electronics. Then id change the battery myself. I used a cell phone battery.
It has worked for the last year.
Regards and I hope this helped.
James
Sketchlab.com
May 28, 2009 | Tomtom ONE GPS Receiver
I have a tom tom go 710 and need to know how to reset it, and when i turn it on, the screen shows that I need to install SD card. I am wondering if I need the SD card for it to work properly?
To reset your TomTomGo710 device, do the following:
    If your device uses an SD card, insert the SD card.
tomtom go710 map data is on SD card without it, it will not work.
Apr 21, 2009 | Tomtom GO GPS Receiver
Tom tom 300
"My tom tom wonts switch on. I have reset it and still it comes on with a boom boom noise and shows the 2 hands on the screen. It also shows the loading bar at the bottom, but then it just freezes and nothing happens. can anyone help please ASAP"
Sound as though your Map data card is corrupt. Remove the SD card and check it with your computer using a card reader. Backup the SD card onto your computer. You can run either chkdsk or go to the drive letter under 'My Computer' right click and select properties, then tools, then check now. You can also try starting the Tomtom with the SD card out of the unit. It should show a picture of the Tomtom with a 'X'. You can also try copying the data on the SD card to another SD card.
Sep 12, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
54 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
