Question about Fuji Cycling
Will not shift into ultra low shifter is shimano tourney sis index
    Guru:
  • 347 Answers
There could be several reasons for the shifting to not be working properly. The most common is that there is too much slack in the cable and you need to re-tension the cable. There could also be something broken in the shifting system or bent.
Best thing to do since index shifting requires precise fixing to make work properly is too take into your local bike shop, they can diagnose the issue very quickly and let you know what is the remedy.
Posted on Apr 01, 2011
Why cant I find any information on my Shimano Tourney RD-TY10 rear derailleur?
Because it's been out of production for some time. There's no useful info to be had anyway. It is adjusted the same as most any rear friction derailleur. It is not useable with indexed levers (click to shift). If you really think you need info do the following Google search: "RD-TY10 site:shimano.com" and scroll through the results.
May 05, 2017 | Shimano Cycling
Exploded view of parts diagram for shimano tourney st-ef40 shifters for re-assembly?
If you can't find with a search for st-ef40 diagram or on the Shimano site then it does not exist. Although not identical carefully disassembling the other shifter may give you enough insight.
Apr 08, 2015 | Shimano Tourney ST-EF40 3x7 Speed Brake...
Shimano tourney TX sis 1. Noise while shifting gear and in motion 2. Chain stucked up at sprockets.
This problem is best taken into a bicycle shop to have them look at it. Could be as simple as adjusting the cable tension, or as complicated as parts not in the correct location or functioning properly. The shop will be able to make a quick diagnosis once they can actually put hands to it.
Jan 02, 2011 | Cycling
What kind of components do I need?
Most bikes have Shimano shifters & deraillers; SRAM is the other main vendor. Shimano makes a wide range; the following table attempts to describe these and presents my best guess of where the SRAM line fits in: Model Quality SRAM Equivalent?
SIS, Tourney (or just says Shimano) Mainly designed for riding around the neighborhood
Altus Sufficient for paved or very easy trails; avoid hills 3.0
Acera Slightly better, but won't shift well under stress; capable for easy casual riding 4.0
Alivio Minimal capable for recreational riding; will handle some hard riding 5.0
STX / Deore Entry-level components for hard riding; tough & reliable 7.0
LX The minimum standard for hard riding. Reliable & responsive 9.0
XT More responsive than LX, but still reasonable tough 9.0SL
XTR Light, responsive racing components; tend to be quite expensive; often sacrifices toughness for responsiveness X.0
Look for a component set that fits your expected riding style.
Note:The numbered SRAM components aren't compatible with Shimano components. SRAM does make grip-shifters that are Shimano-compatible.
There are many other manufacturers that specialize in various components (Avid, Cane Creek, Race Face, Hope) and make great ones. Ask the LBS personnel for a comparison if you see a brand you don't know. Also, you can use the same test as forks above: if its not sold separately, its probably more questionable. If you're getting a full-suspension bike, make sure you get a good rear shock as well (it'll probably be something other than SRAM or Shimano).
Dec 16, 2010 | Cycling
I have a shimano tourney deraileur with sis index. what does the small adjustable screw which is off by itself adjust. the other two screws are for the upper and lower gear stops.
Is it a long screw running into the derailleur hanger? This sets the distance from the cassette to the jockey wheel. You use it to pull the jockey wheel away from the large cassette cog if the chain is having trouble clearing it. You'll know if it is happening because the bike will be making more noise in the low gear and it will sometimes want to skip out of gear.
Sep 13, 2009 | Shimano Cycling
Shimano Tourney rear derailleur is stuck on smallest gear and will not shift. How do I adjust the tension correctly?
There are several things that could be wrong. You could have thrown your chain (you couldn't ride at all if so). The bike could have been crashed and the derailleur bent. The cable might have slipped where it bolts to the derailleur. Or the cable or shifter could need maintenance, too. It is most likely one of the above. If it is only the adjustment, there are two stop screws on the derailleur that can be adjusted.
My best advice for you is to either find a bicycle repair manual at a local bookstore or your library that can show you some of the detail. Or just let your local bike shop do the repair.
Aug 30, 2009 | Mountain Shimano Tourney 6/7 Rear...
Cycling Logo
284 people viewed this question
Top Fuji Cycling Experts
sharky633
sharky633
dante
Donald Ayers-Marsh
Are you a Fuji Cycling Expert? Answer questions, earn points and help others
