Question about Toshiba Office Equipment & Supplies
Dear Sir, One Toshiba DP-1660 is in our office and from last two days we are facing a very small problem but we have no such idea to short it out. When we are switching on the printer after 5 secs. it becomes restart and again and again .....some months before the same problem has raised but the tech. person has inserted some codes on the machine's keypad and after that it ran as usual. but few days before we have changed a toner and now it is the problem plz help me to run my printer/xerox machine. .................Dillip
    Sergeant:
  • 213 Answers
Call your service person. You may have an unaddressed issue he missed the first time.
Posted on May 10, 2017
  • 2072 Answers
SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
Posted on Apr 03, 2008
  • 2072 Answers
SOURCE: Toshiba 850 e-Studio CD20 error
That code means the used toner motor is not running. That is pretty easy to emove and check. You have to take off the right 1/4 cover, normally held in with 2 screws, then remove the toner assembly, on screw on a bracket on top of the assembly and a spring loaded pin on bottom. Unplug the plug and set aside. You then remove 2 screws holding in the used toner assembly and unplug one more plug.
The moror on the top normally is the one that binds, you can try cleaning it and lubricating it lightly.
The recycled toner motor may be going bad. Possibly the auger is bound, and causing it not to run.
I have no clue about the toner you are using, But it is always best to use the toner designed for any printer. But that sounds like it is out of your control. Most of the times its like adding water to the gas tank of your can and then wondering why it doesnt run.
Posted on Jan 27, 2009
  • 13 Answers
SOURCE: sir i have toshiba e studio 163 my machine
u have installed a toner that is not original ,,,try to put an original toner ,,,and then try or let this toner get empty and then try the original one,,,,
Posted on Jul 20, 2009
  • 122 Answers
SOURCE: Minolta c0072 code, hopper or toner?
try the user menu and select toner replenisher. You can find the user guide at
http://kmbs.konicaminolta.us/productsattachments/manuals/EP4000_5000_ops_manual.pdf
good Luck
Posted on Sep 03, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: The printer runs properly but will not print; A blank page cycles
It is not the toner. There are 2 things you can try yourself, anything else requires service. First try opeing and closing the right hand side door. Try this several times if necessary. There are contacts in this door that sometimes don't make contact and opening/closing the door will sometimes resolve blank copies. The other thing you can try is remove the toner then pull out and reseat the drum unit. Here again there are contacts that need to be made that can cause blank copies.
Good Luck and Thank You for using Fixya.
Posted on Apr 09, 2010
I need THOSHIBA e-studio e-dp-1660 printer driver for windows7
Per Microsoft, this printer is not compatible with windows 7.
Mar 01, 2011 | Toshiba e-STUDIO166 Printer
What's 44'H,ME Error
sir i have buy microamx Q5,but sir a have face problem of 44'H,ME Error. sir plz give soulation
Oct 28, 2010 | Nokia 1600 Cellular Phone
How do i unlock my toshiba labtop
hello sir
It's very Easy.. nera the ram u can see small jumper short the jumper for 15 second with flat screw driver.. if same problem ..do again but keep short jumper and turn on laptop for 15 second .... Thanks
Oct 21, 2010 | Toshiba Satellite M305D-S4829 Notebook
My husband just purchased a used vehicle 2-5-10, and it came with this crime stopper keyless entry system with remote start. I'm struggling to get our only remote that we received to work. It is a constant...
good day, you may try checking the battery of the remote for it may need a replacement. usually there a small screw attaching it. hope this helps, have a nice day
Feb 10, 2010 | 4-Button Remote Start/Keyless Entry with...
SP MODE AND INSTALLATION PROCEDURE FOR TOSHIBA DP 1660.
Installation Procedure:
01.Open the machine and take out all tape
02. Open the front cover and right hand side cover + blue lock press and open the black part
03. front side two scrow (big) open
04. Out of PC Unit ( drum and developer Unit)
05. done you Two part the ( drum and developer Unit)
06. developer keep on developer
07. total Items set on the machine
08. main switch on
SP mode
01. 0+5 press and main twitch same time for AJ MODE
02. 0+5 press and main twitch same time for ADMODE
Jan 28, 2010 | Toshiba e-Studio163 Copier
108 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
