Question about LG WD-12126RD Front Load Washer / Dryer
LG WASHER/DRYER Comes up with OE what does this mean?
    Novelist:
  • 116 Answers
OE is a drainage error.
This can be anything from a plugged filter screen to a faulty drain pump.
The filter screen location and cleaning procedure can be found in your owner's manual or online at the LG website.
Posted on Aug 07, 2008
Lg washER AND DRYER. What does OE mean
AN OE code means that the Front Load Washer was unable to drain water.
Jan 11, 2017 | LG Washing Machines
Tip
Appliance Repair Kuna - LG Washer OE Error
OE errors. An OE error on a LG washers suggests a pump problem. Check the drain filter on front bottom of washer for any obstructions. If this is clear, call for service. The pump impeller may be damaged, pump windings shorted, or a obstruction in line.
Rich
Western Appliance Repair Kuna
on Oct 12, 2010 | Washing Machines
Whats the red key and circle llso shows a OE code on LG steam washer wm2487hwm
OE on the LG means the washer is not draining or has a draining issue. When it happened to me I started by manually draining the washer and then running a spin cycle. In a pinch the work around was OK but I could never be certain the wash was complete. Also the wife hated it.
Finally, I dug in and went for a fix. All the hoses were clear and the pump seemed to be working (also the pump screen needed clearing). I found the problem to be a breather hose that runs from the top of the drum to one of the drain hoses. It was plugged and I took it off and blew it out. Problem solved.
Aug 05, 2012 | LG Washing Machines
I have an LG washer/dryer combo wm3987h. I had the OE error which I followed instructions on how to fix now my machine comes on but it does nothing despite me picking a cycle. It does not wash, dry or...
OE = Drain error. Cause: not fully drained within 10 minutes
Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Dec 05, 2010 | LG WM-2277HW Front Load Washer
OE Error
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!!!!!!!!!!!!!!
Jul 13, 2010 | LG WD-14124RD Front Load Washer / Dryer
LG Washer/Dryer won't drain
May 19, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
My LG Washer and Dryer has OE what does it means?
According to the handbook: drain hose is kinked or clogged; the drain filter is clogged.
Solution: clean and straighten the drain hose; clean the drain filter.
I have tried both but have not yet solved the problem.
Feb 20, 2009 | LG WD-3274RHD Front Load Washer / Dryer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG Trom wm2077gw OE error code and won't come off and empty macine I washed a comforter and it shredded part of it and is stuck on OE what does this mean and how do I fix it. Thanks
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
May 20, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WD-12126RD Front Load Washer / Dryer Logo
482 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
