Question about Nokia BH-214 Bluetooth Stereo Headset
The unit shuts down after 2mins of playback, same thing also when charging, the led light turns off after about 2mins
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
It seems that the internal battery is malfunctioning
Maybe you should try get a replace or a new device
Posted on Apr 01, 2011
My hitachi 2nd fix nailer isn't charging, I put the batteries on charge and after about 2mins the light turns off and they stop charging. How can I fix this. Cheers
how old are the batteries.
how old is the charger.
if one or the other is too old or defective,
the bad part will "fail safe"the system.
shut down so it doesnt explode or burn
if it does it with multiple batteries its probably the charger.be sure to check your electrical source too.
bad outlet??
be careful these batts can be dangerous.
Apr 05, 2017 | Hitachi Tools & Hardware - Others
Why does camera shut down?
Your batteries are no good! Digital cameras need a good amount of current to operate and when they are not fed properly they will just shut down!
Nov 24, 2015 | Panasonic Lumix DMC-LX2 Digital Camera
Mitshubishi WD-62327 TV will not turn on and no sound. TV made a interference sound and shut off. Tried to turn it in the morning still nothing. Replaced lamp/bulb still nothing. Red light is on (not...
If you have a voltage meter there are some things you can check.
Unplug the unit and remove the back cover of the set. Then Plug the unit back in.
You will need to tape down the lamp safety switch in order to do these tests.
Here are all the failures that would give you a lamp error and what to check.
Cause 1. Unit powers on and works properly for a while then shuts off with a red lamp led(lamp error). Suspect bad lamp and replace.
Cause 2. Unit does not power up correctly and you have red lamp led(lamp error). Check the lamp enable line at connector J14 on the back of the light engine. If pin 6 does not switch to 5 volts after turn on, but your 12 and 5 volt supplies are good, then suspect a defective light engine.
Cuse 3. At power on the lamp turns on and off 3 times and then the unit shuts down with a red lamp led(lamp error). You have a defective light engine.
Cause 4. Unit does not turn on correctly and you have a red lamp led(lamp error). Check for 12 volts at connector J9 pin 4 on the light engine. If voltage is missing check for an open fuse F9A09 on the power supply board. If it is open, then you need to replace the fuse and you still have a defective light engine.
Cause 5. Lamp enable line at connector J14 pin 6 on the light engine does go to 5 volts at turn on, but does not drop back to 0 volts after 5 seconds, but your 12 and 5 volts supplies are good then you have a defective light engine.
Cuase 6. Check for 5 volts at connector J9 pins 1 and 2 on the light engine. If low or missing check Capacitors C9A37 and C9A38. Values are 3300MF/10V. Replace capacitors if defective.
This is all I have and I wish you luck.
Mar 20, 2013 | Mitsubishi WD-62327 62" Rear Projection...
E1 shows and i unplug the unit and it will run for about 2mins and shut down with e1 showing
The E1 error code indicates that the air intake filter is dirty or clogged and needs to be removed and cleaned. Turn the unit OFF & unplug it, before removing the filter. Never operate the unit without the filter in place. Doing so, can damage the unit.
Hope this helped you & thanks for choosing FixYa.
Sep 20, 2011 | Haier Heating & Cooling
Green battery light on the archos 5 but when i disconnect it from dock or usb no green lights abd completely dead - won't switch on either in dock or out???
Power green LED light should come on, CHG green LED light should also come on showing the battery is being charged. Leave your unit in Suspend mode while charging it, DO NOT turn it completely off as "Shutting Down.." because it will not charge your battery.
I just purchased an almost new Archos 5 on eBay recently, and the first day I had it, happened to me that I left the unit off and charging on the Mini Dock with external AC power supply, after 13-14 hours the CHG light still wasn't blinking. Then I though maybe I have to leave the unit in Suspend mode rather than completely off, which I did, and in a matter of 3 hours it fully charged the battery.
Again, do not shut down completely the unit, leave it on Suspended mode, or even on, and connected it to your mini dock, after a while the screen will go blank the unit will go into Suspended mode by itself, and after 3 hours on external power supply or 8 hours via USB on PC should be completely charged and your CHG light should be blinking, indicating the battery is charged.
I hope this helped.
Mar 10, 2010 | Archos Internet Media Tablet MP3 Player
Motherboard red light stay on and computer won't turn on. Any ideas on what the promblem might be?
First try shutting down you're system. Than turn the PS off at the rocker switch (Back of PS). Ground you're self by touching the the PS. Remove you're memory and re-seat it. Than boot the system.
Check the standby LED. See if it lights green.
Pull the cmos battery and check its voltage. Anything under 2.4 volts replace the battery. Normally the MB LED displays green. (Standby power).
This means the MB is maintaining / charging the cmos battery. If the battery can no longer maintain charge this will cause the MB LED to turn Red. Built into the mother board is a small switch. When the system is shut down the MB maintains power to the cmos. If the standby switch fails to function correctly the LED will turn Red. Lets hope the problem is the cmos battery. The internal switch can not be repaired.
Cheers'
Mike
Feb 02, 2010 | AOpen S651M (918EM10S50) Motherboard
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
My ds is automatically shutting down..
put the charger in and then turn it on
Jun 19, 2009 | Nintendo DS Lite Console
Sony Grand Wega KF50WE610 Video/Audio disappears every 1-2mins
Hello apharcha,
99.99% its the lamp. You may also have a faulty door, but thats kinda just 2% possibility. Change the lamp...its due anyway.
List Price $200.00
Part Number A-1606-034-B Description LAMP BLOCK XL2100U
Best regards
circuitcity
Jun 08, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
After 2 years, erratic behavior.
Lens unit problem. Either imact or sand etc in the lens zooming gearbox area. Maybe uneconomical to repair on this model if new lens unit has to be installed. ( it is shutting off because the lens does not come on line properly and so the shutter and CCD do not come on line... when this happens camera switches off. )
Aug 04, 2007 | Fuji FinePix S3100 Digital Camera
Nokia BH-214 Bluetooth Stereo Headset Logo
119 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
