Question about Toshiba Se-r0001 Remote Control
How do I replace the batteries on my Toshiba SE-R0001 remote? thanks
SE R 0066 remote does not talk to toshiba SD- V260 VCR/ DVD
Try replacing the battery of the remote control look like run out of power
Sep 04, 2016 | Toshiba Televison & Video
Hello my Toshiba SE-R0398 controller is not working. I ahve tried changing batteries. Any possible solutions to this problem?
Search Results
    Where is my User's Guide / Owner's Manual? - TOSHIBA FORUMS
    forums.toshiba.com/t5/Toshiba-Forums.../Where-is-my.../268741
    May 28, 2013 - Answer. Most products do not include a printed manual but Toshibaoffers free, downloadable PDF User's Guides at support.toshiba.com.
    1 - Toshiba Blu-ray Players : Questions, Answers, How To ...
    answers.toshiba.com/answers/0293/category/.../blu.../questions.htm?...
    It had been working fine. Wired to modem, home computer working fine. It does a ...My remote SE-R0377 will not operate my BDX3200KY player. Im not sure if ...Missing: controller
    Remort se-r0398 not working - Fixya
    www.fixya.com/support/t16019942-remort_se_r0398_not_working
    Jan 20, 2013 - remort se-r0398 not working remote and buttons on blu-ray player not working model bdx1100kb - Toshiba SE-R0398 ... Question about Toshiba SE-R0398Remote Control AH802703 ... I need help with syncing my controller!
    Toshiba Blu Ray Remote ' eBay
Jan 14, 2016 | Toshiba Computers & Internet
Toshiba SE-R0340 remote control for RD100kb HDD/DVD recorder: only some buttons work. I can use select, guide, on/off but not Top Menu, fwd/back, skip fwd/skip back etc just nor response to these at all...
open the r.control and clean the keypads with contacts cleaner from dirty, corrosion, oxide, replace batteries and clean contacts batteries from oxide too. try again.
God bless you
Sep 24, 2013 | Televison & Video
My toshiba remote (se-r0305) changes tv input when I push the channel up/down button instead of changing the channel? It came with my toshiba 22lv50k tv, and all other buttons are functioning properly.
The remote control need cleaning. Just enter this site named [Electro-Help]. It has all details about how to clean and repair a remote control. Google for it.
Apr 30, 2012 | Toshiba SE-R0305 Remote Control
Ordered a new Toshiba SE-R0177 remote for TV model #15DLV16. New batteries installed. How do I set it up? It did not come with a manual and the original manual no longer exists. Can't find one online...
. Make sure there are working batteries in the Toshiba remote control.
2. Turn on your television set, DVD player or other device that you want to control with the Toshiba remote.
3. Find the "Recall" or "Setup" button on the Toshiba remote control. After you find it, press and hold down that button until the lights on the remote control turn on and remain lit.
4. Point the Toshiba remote at the device you turned on in Step 2 and press the button on the remote for that device.
5. Begin pressing the "Power" button on the Toshiba remote. Continue doing this until you have turned the device off using the Toshiba remote. Once it shuts off, press "Enter" on the Toshiba remote. The remote will then be programmed
OK.
Mar 17, 2011 | Toshiba Se-r0177 Remote Control
Where is the volume control on the toshiba se-r0313?
There isn't one. This is a dvd player remote. You will need to control the volume with either your tv remote or surround sound remote if you have surround sound
Mar 08, 2011 | Toshiba Se-r0313 Remote Control
Hello, I have had my Home Theate packed for a few years now. I have 2 Toshiba remotes. Neither of them operate the system. One is an SE-R0094 and the other remote is an NB001. I tried new batteries in...
The SE-R0094 is the original remote for the SD-KT50. So should work with it unless it's faulty.
You can get the service manual for the SD-KT50, that might give you clues as to why it doesn't work. It's free the manual, just type the model number into Google.
Jul 06, 2017 | Toshiba SD-KT50 System
My Toshiba SE-R0161 Remote no longer works.
There is most likely nothing wrong with your remote. I just had exactly the same issue with my SE-R0161 remote. (I had just changed my remote batteries too and was getting a DR-2 code on the Toshiba DVR RD-XS52 unit's display.) My DVR and my remote had to be realigned so that they both have the same infared (IR) code. The remote and the DVR can have DR 1, DR 2 or DR 3 as remote codes. Pg 54 of the Toshiba Installation Manual explains how to align both your SE-R0161 and your based unit so that the remote works again. Good luck. Hope this helps.
Mar 27, 2009 | Televison & Video
Toshiba Se-r0001 Remote Control Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
