Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
What type of bolt do I need for the 21" blade for a YARD MACHINE 1399cc m#11a-54mr029 / S#1j347k11303
    Novelist:
  • 111 Answers
You will need MTD part number 710-1257. Or if you have a bolt and screw place it is :Hex Screw, 3/8-24 x 2.5. Hope this helps.
Posted on Apr 03, 2011
I NEED TO KNOW HOW THE BLADES GO ON A 21' SELF PROPELLED MOWER THAT IS A MULCHER
Most lawnmower blades simply attach with a bolt through the blade which bolts into the bottom of the crank shaft. The blades usually have a curve at the end of the blade, and this curve would point up when properly installed. If you post the model number of the machine, I can probably point you to a schematic which will show exactly how your blade mounts.
Tim
Oct 24, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
20" lawnmower 3.75HP Model #11A-072A022
Lawn mower blades bolts are reversed thread. Its righty loosen, lefty tighten....
May 07, 2011 | Garden
I RECENTLY BOUGHT A PUSH MOWER AT A FLEE MKT..NEVERNHEARD OF A QUATTRO MOWER...IT HAS A 22 IN BLADE..I HAVE AN OLD 21 IN BLADE FROM A L-BOY..CAN I USE THAT ON THIS MOWER OR MUST I BUY NEW 22 IN BLADE ???...
i just looked up Quattro mower they are a 4 stroke engine and yes i would buy a 22 inch blade but be sure it fits this mower PS go to wall mart and check out their blades they are reduced now.
Sep 09, 2017 | Yard Machines 158cc Push Lawn Mower #11a...
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Oct 08, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Lawn mover will not start, was flipped over
The clicking noise may be the blade hitting the side of the mower or it was not put on properly. It needs a balance to the aluminum flywheel on top of the engine. The blade adapter and blade provide this balance for the engine to run.
Good Day.
Oct 07, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Need wheel nuts and bolts for a Ryobi 21 inch 6.25HP walk behind lawn mower model #11A-546P034. Part number would be great. mtymon8019@aol.com
A good hard ware store will have the shoulder bolts you are looking for, take a wheel with you, the solid bolt part should be just a 1/16 of an inch longer than the wheel hub
Mar 21, 2009 | Garden
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
101 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
