Question about Samsung UE37B6000 37 in. HDTV-Ready LED TV
How do I connect a DVD player which has a scart that does not fit in new televiosion - connections to large & i can't find a connection on back of TV
  • 577 Answers
Hi, I recommend that buy an SCART to RCA/S-video adapter and use that one connection..
here is an example of SCART TO COMPONENT & S-VIDEO adapter on the URL below..
you can have a cable that one end SCART and the other end whatever you have on the TV..
check on eBay..
http://cgi.ebay.com/SCART-COMPONENT-AND-S-VIDEO-/140482348595?pt=LH_DefaultDomain_0&hash=item20b5668633
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Posted on Jun 24, 2011
Connecting a dvd player to a logik tv
see the diagram attached: God bless you
Jul 21, 2012 | Televison & Video
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Dec 30, 2009 | Nintendo Wii Console
How do I connect a JVC DVD video player model XV-S302SL to a cable box and a TV
There are several ways in which you can do this.
The first way. If your cable box has two scarts one will be label as tv and the other vcr or something similar. connect your Dvd player via scart to the vcr scart on the back of your cable box. then connect a scart from the cable box to the back of the TV.
That would be you all sorted. when you turn your DVD player on this should override your cable and display the dvd screen.
Second way. If your cable box has not got two scart ports on the back of it. Then you would have to connect both to the back of your TV. If there are not two scart ports at the back of your TV then you can purchase a scart lead splitter. I would imagine the Cheapest you could find would be on Ebay or something similar.
Hope this Helped Clarify things for you.
If this has then please leave a thumbs up
Cheers Little Dish Fitter.
Oct 14, 2009 | Televison & Video
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Aug 27, 2009 | Televison & Video
Cant get a picture on tv using dvd but can get sound Samaung dvdR120
I assume you're using a Scart connection between the DVD & the TV. Try re-fitting the scart into both the DVD & TV, it is common for the scart cable to become slack & will give you this symptom.
Jul 12, 2009 | Samsung DVDR120 DVD Recorder
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
Can see no way of connection to terrestrial TV, no scart connection?
easy dose it have rf out? or phono out if you have phono out buy a phono to scart lead to conect
Apr 28, 2009 | Televison & Video
Just bought a lcdtv. would like to connect a Goodmans dvd recorder. My new Samsung TV has two scart s in the back panel, apart from the power scart. Which scart do i connect to the recorder?
should have a scart in and scart out, will be written above or below the scart as to whether it's a input or output, failing that try both to see which works you cant harm the unit by having the scart wrong, enjoy
Sep 03, 2008 | Samsung Televison & Video
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
Samsung UE37B6000 37 in. HDTV-Ready LED TV Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
