Question about Whirlpool 17.6 cu. ft. Top Freezer Refrigerator
Water leaking from top freezer - Whirlpool 17.6 cu. ft. Top Freezer Refrigerator
  • 415 Answers
The freezer drain is plugged and must be flushed out.
Posted on Apr 01, 2011
Maytag mtb2156de freezer leaking through the top of the frig. The freezer is keeping things frozen, but water is running onto the floor.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Aug 28, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Water comes out from under the refrigerator every three or four days. I checked everything under. The water hose is find no leaks. The water tray under is empty. Is not a large amount of water maybe...
I dont know if you have a side by side or the freezer is on top,but thats a fairly common thing and the following is what i already wrote before what to check when it leaks like your experiencing.
SIDE BY SIDE
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
FREEZER ON TOP
I hope this will hepl you to fix that leak,
GENE
Aug 17, 2011 | Refrigerators
Water is leaking onto top shelf of fridge. It is a top freezer.
Sounds like you have a frozen drain in the freezer. You can remove the back panel of the freezer and take a turkey baster and run hot water down the drain line to clear it. Once its cleared you will want to dump an additional cup of water down to make sure that its clear. This will stop the defrost tray from overflowing when the unit goes into defrost. This is where the water is coming from.
Hope this helps _MJ_
Feb 16, 2010 | KitchenAid KSRA25ILSS Side by Side...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water is leaking on the top shelves in my kenmore refriderator water is leaking on the top shelves in my kenmore I have water leaking onto the top shelf of our Kenmore refrigerator. I believe it goes into...
During the defrost cycle heaters inside the walls of the freezer turn on to melt the frost. The melted frost "water" is supposed to drain into a pan under the fridge where it will evaporate. I think the drain line from the freezer to this pan may be blocked. I'd also check the seal on the freezer door. If it's not sealing well it lets a lot of moisture into the freezer which means more water during the defrost cycle. I'd also recommend checking to make sure the ice maker is not leaking.
May 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer.
Freezer Noise. Water leaking in Fridge.
you need a repair man.you have a defrost problem and your drain is clogged.
Mar 09, 2009 | Haier HTE18WAA Top Freezer Refrigerator
Water leaks into the freezer
under refrigerator you soposed to use hot water
Dec 22, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
Kenmore refrigerator leak
I have an Amana refirgerator with a top freezer and had the same problem. I turned off BOTH the frig and the freezer for 24 hours. That allowed every thing to dry out. It has been running now for a week with no problem.
Jun 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Whirlpool 17.6 cu. ft. Top Freezer Refrigerator Logo
62 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
