Question about Zebra LP 2844 Thermal Printer
Hi - I've tried everything to get my Zebra LP2844 to print 4x6 USPS labels directly from Ebay...to no avail. They come out too small, turned the wrong way, etc. etc. Has anyone else had this problem...any idea how to fix. Drivers appear properly installed (I'm on Windows Vista), printer is communicating with computer, I have printer set as default - 4x6 in portrait mode. I just don't get it. Can you help? Thanks, Michael
  • 20 Answers
Change the setting to landscape.
Posted on Apr 01, 2011
Zebra gk420d not printing shipping labels properly on ebay
You have to go to printer drivers on your Operative system, then open printer properties, general tab, you will be able to check the horizontal/vertical setting of the label there.
Mar 02, 2014 | Zebra Gk420d Direct Thermal Printer -...
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
Error message on stamps.com says: error initializing printer. I have used this printer lots and lots of times and this just started popping up.
ok 2 things either your firmware is outdated or your driver... i do have the same problems due to my driver is not correct...plus when i updated the driver i forgot to set printing orientation and paper size
first go to
http://www.seagullscientific.com/aspx/thermal_95.aspx
scroll down to zebra click download
then install it
you will see 2 printer in your printer and fax in control panel
right click on the LP2844 (not the Zdesign LP2844)
select printing preference
go to page setup tab
choose 4x6 from the drop down menu in(stock)
then apply
also dont forget to go to option to set the darkness uncheck the use current printing setting
go for 12- 14 the default setting is to light sometime might not scan..by usps...
since everytime you updated the driver ...your setting might go on default...that why you'll need to go back and reset the printing pref...
after i did it ...the stamp.com doen't have problem at all
hope this help
http://www.etsy.com/shop/iamyot
Oct 06, 2010 | Zebra LP 2844 Thermal Printer
How to print portrait 4x6 labels from USPS using my Zebra LP2844Z
There is a much better driver to use for Zebra printers and it come free from www.seagullscientific.com. Look for the drivers download and then pick Zebra.
Hope that helps.
Mar 23, 2010 | Zebra LP 2844 Thermal Printer
ZEBRA LP 2844 PRINTING PROBLEM IN USPS SHIPPING ASSISTANT
Are you sure that the page size is wrong, or are you just guessing because of the way that the label is printing? I would uninstall the driver - delete the printer from printers and faxes and remove the driver from Server Properties (in the file drop down in Printers and Faxes). Go to ups.zebra.com/ctp and get the latest driver - you have to have the UPS version of the driver in order to support pass-through printing. Go into your UPS Ship Asst application and make sure that the generic thermal is not checked.
Jan 15, 2010 | Zebra Eltron LP 2824 Thermal Printer
I have a Zebra LP2844 Thermal Printer from UPS. I
Welcome to the club. Been fighting this for almost a year. There is now a driver for vista available from Zebra to fix. I can now print 1 label from quick books. to print a second i have to restart computer and quick books. still searching for the answer.
Dec 08, 2009 | Zebra LP 2844 Thermal Printer
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
Hint:
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
Dec 02, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Jun 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
I need the driver for Zebra LP 2844 for MAC OS X.
OS X 10.5.2 and above have built-in ZPL and EPL drivers. Plug the printer in to USB, go to System Preferences > Print & Fax, click + , and choose the Zebra driver. For the LP2844 you choose the EPL2 driver.
Apr 09, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2844 Thermal Printer won't print from a browser
I posted this problem last week and since that time discovered the problem (at least for me). I had to replace the HD and failed to update a current version of Java. Without Java in place I could call for it to print but the print job would disappear into thin air. After installing a current version of Java the machine began printing again and has worked perfectly.
Jan 14, 2009 | Office Equipment & Supplies
Zebra LP 2844 Thermal Printer Logo
533 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
