I have a new Epson Work Force 30 Ink Jet printer. Regardless of the text that it is printing, it prints horizontal lines through the text for the entire length of the 8.5x11 page. Is their a fix? What else do you need to know to be of assistance?
    Brigadier General:
  • 3,513 Answers
Hi
Run a cleaning page through it, from the printer control pannel in windows if that fails try running the printer head alignment program. Check in your printer manual, you should find instructions on both in there. Manually remove the print head and then rub the print head in a plain paper with isopropyl alcohol until ink flows. Return the ink cartridge into the printer and run the print nozzle for 2-3 times.
Confirm that the head cleanings were done using the most effective method listed below.
Select Hard Drive > Applications > Utilities. Open the Print Center. Proceed to Step 2.
Highlight your printer in the list and then select the Utility icon at the top of the window or choose the Printer Utility in the Printers menu.
Select Nozzle Check > Next.
Examine the pattern that has printed. Each staggered horizontal line and straight vertical line should be complete and matching the pattern viewed on your screen labeled Good.
If all the lines do not meet then you must clean the printheads by clicking Clean. Click Finish if the nozzle check pattern has no gaps.
After the printer has finished cleaning, click on Confirmation. Another nozzle check pattern will now be printed. If it is solid without any gaps, click on Finish. Otherwise, click Clean. Perform this step up to two more times, if necessary.
If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
Once the cartridge(s) has been replaced, please follow steps one through six up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 01, 2011
Horizontal lines on page
Your printer head - the ink cartridge in case of most HP deskjet printes, in most cases is defective and you need to replace it to have a clean print.
Anyway, read this tutorial, has some good tips:
HP Deskjet D2500 Printer Series Horizontal Streaks or Lines in the Printed...
For Epson printers, read this
Epson Stylus Color Ink Jet Printer
Epson Printer Horizontal lines
Same for Cannon priters
Horizontal lines when printing with Canon ip4500 Forum Thread
Aug 23, 2015 | Office Equipment & Supplies
My printer has problems printing dark colours. When printing pictures or text, it leaves horizontal lines on black only. I have a continuis ink system which has lots of black. Any ideas?
Try changing the print paper type to something other than plain paper. Use the matte paper setting, or the photo glossy. The printer will lay down more ink at these specialty settings.
Jan 24, 2010 | Epson Artisan 800 All-In-One InkJet...
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Comments:
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Remove the cartridge(s) and use an alcohol swab to reach inside and clean the print head surface where the ink comes out.You may have to move the head with the power turned off to get at it or turn the printer on it's side to be able to reach under the head to clean. Q-tips work fine for that and it will likely take quite a few.Clean until there is no more ink on the q-tips. Also clean all rollers and surfaces where ink can collect. A defective head will also do that as it sometimes leaks excessive ink when printing.
Aug 29, 2009 | Epson Stylus C46 InkJet Printer
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Epsom stylus C66 inkjet printer
Hi
This problem is probably caused by a blockage in the ink waste pads. Over time, particularly with increased nozzle cleans the pads get saturated. These can be replaced by an Epson Engineer at a cost of about £30-£40 but probably more effective to buy a new printer. This usually happens when the printer is between 2-5 years old.
Hope this helps
Sarah
Oct 10, 2008 | Epson Stylus C66 Inkjet Printer
Ink
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 19, 2008 | Epson R245 InkJet Photo Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
White lines throught the print
Try cleaning printheads through printer driver.
Nov 25, 2007 | Epson Stylus C88 InkJet Photo Printer
k24674
jasbo
jasbo
