Need to know tonnage of goodman condenser model # ssz140361ab
    President:
  • 1,515 Answers
If this is the correct Model number, you have a 3 ton unit. 036=36,000 btu. 12,000 btu per ton.
Shastalaker7
A/C, & Heating Contractor
Posted on Apr 01, 2011
2002 need model number to answer tonnage
Aug 25, 2014 | Goodman Heating & Cooling
Trying to find the tonnage of my goodman a/c model number aruf486016ba
Does this happen to be the number on the indoor blower coil. The 4860 would either be set up to handle either 4 or 5 tons. If this is so, you need to look on the outdoor condenser to see whether a 4 or 5 ton condenser was coupled to the unit.
Mar 20, 2011 | Coleman Heating & Cooling
I have a Goodman CPLJ24-1B condenser unit & am needing to know what tonnage it is guessing 2 tons? Would this be big enough for 2000 sq ft of floor space? Block building with no wall insulation.
Yes, it is a 2ton unit and no, it's definitely not big enough. You need 1 cfm per square foot. That's 2000 cfm. 1 ton of air is equal to 400cfm. So you would actually need around a 5 ton unit to comfortably do a 2000sq ft building. Insulation, doors, windows, and other sources of heat load all factor in, but this is the standard formula. Hope this helps!
Jun 19, 2010 | Goodman CPLE24-1 Air Conditioner
Goodman model F48F97A76 need to know what the
if your condenser fan motor is not bad. change out fan capacitor
Apr 08, 2010 | Heating & Cooling
What ton is good man ckl 49 il where is the model number onthe furnace
ok ready for this? To find the tonnage look at the serial # Tonnage is related to 12's If there, on the serial # there is say 0062490 the tonnage is 24 or two tons 24 divided by 12 equals 2 Say the serial # contains 0063090 then the tonnage is 2 1/2 because of the 30 hopefully you see what I am saying the number in the serial # if it can be divided by 12 or 6 this is the tonnage. If you will send me the serial number I will tell you the tonnage. The serial number is on the outside unit at the copper connections where the electrical lines go in.
Good luck on your repairs hope this helped send me a note online here and if you need I will give you tonnage if you send the model # and serial number with your response> I will check online around 1500 hours on 1/9/10 central time. Remember to look for the numbers that are divisible by either 12 or 6 on the serial number
Dave
Jan 08, 2010 | Goodman CKL60AR60 Air Conditioner
What is the tonnage of model # ce60-1fb,also manufacture date?
That is a 5ton condensing unit.(12k btu per ton).If the manufacture date is'nt on the outside of unit,you should be able to find it as well as serial ect.....On the inside of the service panel.
Jan 06, 2010 | Goodman Heating & Cooling
I would like to know the specifications of my Goodman model CPKE42-18 AC/Heat pump system. BTUs heating and cooling? Thank You,
Many HVAC people talk in tonnage. One ton is equal to 12,000 Btus. Therefore your model specifies your cooling tonnage at 3 and 1\2 tons. Your heating would be determined by how many if any supllimentary heat strips are added. If you live in Anahiem or Miami that's not really important. But if you live anywhere that gets down into the 40's at night you'll want strips. Cooling wise depending on where you live and what your insulation is like, I'd say your unit is good for 1100-1300 Sq feet of living space.
Jul 15, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
