Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
There is no suction on Hoover Floormate. Have cleaned everything I can see or remove
Check the hose from the base to the water channel when handle is down, and see if the hose is split and open. it becomes brittle and breaks as it ages.
Posted on May 10, 2011
Hoover floor mate h3000 will not suction water from floor when cleaning
Your collection canister may not be positioned tight enough in its place ment site. Tip machine back using foot pedal (as if you were going tio start using machine to clean) Insert collection canister (bottom container, then insert top canister with solution. The two canisters must be flush with machine side seams and must sit in position tightly. This is sometimes very tricky and may take a little elbow grease to make it click into place. Hope this helps
Jul 08, 2015 | Hoover Floormate H3000 Upright Wet/Dry...
While cleaning with the floormate the dirty fluid dropt out and it willnot pick up.
sounds to me that something is blocking the suction from the impeller. You might just have to lay down some newspapers and go to town cleaning the unit. Remember it is a machine, and it has to be maintained.
Mar 04, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
My floormate is not suctioning very well. Tech support told me to take out the brushes and put them back in and this helped for a little bit then it went back to not suctioning. deb
When you took the brushes out, was there hair wrapped around them? Sometimes they just need to be cleaned off. When you take them off, there is a belt they connect to that also goes around a gear -- make sure the belt and gear don't have hair wrapped around them either.
Hope that helps!
Aug 28, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
No Suction
The water channel hose could be torn. you can check by removing the lower tank and tilting it backwards, it is located in the lower section. could also be the filter cover. it is needed for full suction control.
Oct 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Troubleshoot floormate spinscrub 800 floor cleaner
The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
No suction throught the hose
sounds like its blocked stick the broom handle thru it , there might be something plugging the hose under the bottom at the connection
May 22, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
HOOVER FLOOR MATE WILL NOT SUCTION WATER
There are no belts. If it makes the noise with the brush assembly removed the motor drive assembly is bad. It ia a complete assembly that can easily be replace by a repairman or ypouself if you are cleaver with tools. Good luck.
Kirk Thompson
San Juan, PR
Oct 17, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
buy a new solution tank. the problem might be that your not rinsing the tank with clear water after use and the soap hardens on the release button of the tank.
Feb 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover Floormate has lost most vacuum capability
Check to make sure that the filter cover is in place. This is commonly lost or misplaced. It is a clear-blue plastic cover that lines up with the motor intake and acts as a link for the tank.
Also, check the squeegees and make sure they are not torn. If they are, they will not allow the suction to concentrate in the nozzle. Also, check the black plastic wheel assy under the machine. These are notorious for breaking at the pivot pins at the back and this will not allow the machine to sit on the floor properly and will contribute to this problem.
Jan 17, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover floormate
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Dec 15, 2007 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
159 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
