Question about Electrolux EW1000i Front Load Washer
How do you uninstall the water hose? i have been trying to uninstall it but it seems it is 'locked' to the machine
  • 415 Answers
Are you speaking of the fill hoses if so then they are just on the unit very tight but if you are speaking of the water drain hose it is not designed to be removed.
Posted on Apr 01, 2011
How do I correct a 4E error?
try unpluging for 15mins re try
Apr 27, 2015 | Samsung Washing Machines
The cold water is not flowing well into the machine. It is just dripping. I've swapped the hose with the hot (this has not helped). The hose, when disconnected from the back of the machine seems to have...
Hi just read your posting.Now the place you unscrewed the hose from on the machine end is the water valve.If you look at the water valve from the back of the machine you should see a plastic filter inside the water valve.Clean this filter if it is blocked.Now refit hose to machine and try a fill cycle again.If it still has inadequate water flow then the water valve needs replacing.If it needs replacing I can guide you step by step to replace the valve.Looking forward to your reply.
Oct 03, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
No water pressure.. bad pump or motor?
Try filling water from the front manually. Check whether every thing works normal.
If works OK, check your water inlet for free flow.Try the inlet hose externally by flushing water through the hose.
Check whether any air lock. If air lock noticed, air will flow in broken streams.Flowt will become OK after some time.
Try now in the machine by connecting.
Mar 31, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
Have a maytag mah5500bww replaced door lock still do and fl code
fl is usally a water not detected problem,, check ur fill hoses for kinks make sure ur water is on,, possibly have a bad fill valve..
Feb 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Machine fills up only half way....water eners very slow....afta machine stops, I get a PF 6 reading
Try removing each inlet hose in turn and check for water flow from each hose. If seem slow, try reversing that hose to back-flow the inlet filter screen which should remove loose debris, but won't affect any hard water deposits (soak the screen end in white vinegar and hot water for an hour or so). If both hoses flow well, check the entry holes in the machine for plugged screens. If all else fails, replace the twin inlet solenoids. Hope this helps!
Feb 01, 2010 | Amana ALW480DA Top Load Washer
Hi i am having trouble with our wma58, the last 2 washes it has sounded noisy on start up but then washed fine yesterday i put the machine on it seemed to get half way through a cycle then stop all the...
Try the following.
Remove lower rear panel of washer.
Locate and remove the large black hose fastened to the bottom of the drum.
Remove and clean the filter inside the hose.
Remove the black hose onto the pump, and check for blockage or obstruction here and in the pump.
Hopefully, this will solve your problem.
Good luck.
Dec 13, 2009 | Hotpoint WMA58 Front Load Washer
Cold water or cold & hot water connection?
If there is only 1 water connection on the back of the machine then it's a cold water supply only and the machine will be fitted with a heater element to heat the water. If it has 2 water connections then you need the hot supply and should ask someone to fit the correct isolation valve on the capped pipe so you can fit the required hose. Most modern machines are cold water only.
Apr 11, 2009 | Bosch Washing Machines
NOT DRAINING
See if you have a sock in the inlet hose at water pump. You have a pressure switch that will not allow the machine to advance until the water has been pumped out.
Nov 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Wd63 door
The main cause with this model is water still in machine. Try a spin and look for water in drum. To empty manually lower drain hose into bowl untill empty. Door should then open.
Nov 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Hoover Premier 706 (model A6950) washing machine.When filling water wont shut off.Turn power off water shuts off.If I remove hose from side of bowl and gently blow into it water shuts off.Machine is old...
Inserted flexible piece of thin wire into hose connectioin on outside of bowl and vigoursly wriggled it around - replaced hose and bingo water fills and shuts off and machine operates correctly. Seems like the hose connection was blocked, not a very scientific repair method but seems to have worked. Thanks.
Aug 14, 2008 | Hoover Washing Machines
Electrolux EW1000i Front Load Washer Logo
27 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
