Question about Dell Inspiron 530 Desktop Computer
My Dell Inspiron does not boot up only the solid amber light on the Motherboard on I try everything and still nothing works please help
  • 48 Answers
Not so sure about this but I hope this will help.
-try to disconnect all the cables from the back (monitor, keyboard, mouse, usb's, power cable, etc.)
-then disconnect all the card (video card, sound card, NIC) if all are integrated then you dont have to.
-connect just the power cable
-try to turn on the computer and check if it beeps
-if it does not beeps need to replace the motherboard but before you do this check if the fan will spin even for a single second if does not spin then you also need to replace the power supply as well
-if it beeps then turn it off again.
-connect the video card and connect the cable of the monitor, keyboard and mouse
-turn on the computer then check if theres any display
-if theres no display check for any beep indication. and right it down on a piece of paper on how many times it beeps and if its long beep or short beep.
kindly provide an email if this things does not work so that I can give you a resolution.
Posted on Apr 11, 2011
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
My dell 545S will not boot up it blinks amber for about two minutes then turns solid amber and the funs(all three) run but will not start!!!
If you are not getting any beeps its either the powersupply is back or the motherboard is bad. You can try replace one at a time
Aug 11, 2014 | Dell Inspiron 535s 537s 545s 546s 560s...
Dell troubleshooting
Most likely there is something wrong with either the motherboard, cpu, or RAM. Check out the troubleshooting steps at:
http://bit.ly/ZRBZvZ
Jan 28, 2014 | Dell Inspiron Computers & Internet
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Dell dimension 2400 diagnostic led lights abc=off,d=amber, please help
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm#1105412
Since that isn't one of the listed codes, it is important to see what the POWER LED indicates.
If it is Flashing Amber, most likely a bad power supply
If power LED is solid amber, then either the motherboard, or a expansion card in the motherboard has failed. Remove any expansion cards, (Modem, sound or video card) try booting again.
If no Change then a motherboard
Jun 26, 2011 | Dell Dimension 2400 PC Desktop
Dell 4700 desktop, will not boot up. Light remains
A solid Amber power LED is an indication of a motherboard problem. Remove any external connections and see if LED indications change. If no change, remove all PCI expansion cards, try again. If still no go, disconnect all drives, try again. If still no change, ensure the CPU heatsink is firmly attached (If loose you need to replace the retention module) If nothing loose and no changes from other steps, replace motherboard
Mar 11, 2010 | Dell Dimension 4600C PC Desktop
I removed memory while computer was on, now it wont power on and boot a solid amber light stays on. how can i get my computer to work
While PC was on? You might have damaged the whole motherboard.
Try removing all non-essential devices and booting it to minimal. Try another stick of RAM. IF still nothing, the motherboard will need replacing,.
Feb 16, 2010 | Dell - Board,System,Dimension XPS,P2,PURCH...
Solid Amber light when starting the Inspiron 530 . Every time i start the Dell inspiron 530, the solid amber light comes on and it dont start. As per Dell user manual i have tried everything but of no use....
Amber led simplifies a start-up-error. This could be a number of things.
For example:
Check if HDD is connected properly
Check if RAM is connected properly / also if this is damaged your pc wont start.
Check your m/board for any loose capacitors an if they are not popped at the top.
Your LCD screen is properly plugged in to the m/board and if the cables aren't damaged they are very thin and fragile.
also could be the power supply...
Goodluck
Ryno Gerber
Jul 30, 2009 | Dell Inspiron 530 Desktop Computer
SOLID AMBER LIGHT ON DIMENSION 3000
One of two things:
Either the power supply is marginal
or
Good luck.
Mar 09, 2009 | Dell Dimension 8400 PC Desktop
Dell Inspiron 530 Desktop Computer   Logo
369 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
