Question about Maytag Refrigerators
I have a 21 C/F top freezer modle #mtb2194arb the compressor seems to still be working as there is still ice cubes in the freezer . the fan was squeeking and clunking the other day then stoped working . so there is no air movment? Is this an easy fix? Thanks.
  • 415 Answers
Yes, it would be one of the more simplest repairs but before you start write the model # down and call your local parts house to see if they have the part in stock first then the screws on the rear back panel must be removed to axcess the repair but do unplug the frig to get no surprise's.
Posted on Apr 01, 2011
Hi i have installed my american fridge freezer DAEWOO FRAQ19DCB but the ice cube maker don't seem to be working. There is not even any water going in to the ice cube tray but there is water going to t
The inlet water supply solenoid valve has two coils and valves. The icemaker valve is not functioning either electrically or mechanically. Best bet is to replace the complete assembly.
Jan 25, 2015 | Daewoo Refrigerators
My refrigerator stops working yesterday. Compressor and compressor fan seems to be working....inside fans are working but its not cooling, freezing or making ice.
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. The relay is a small usually black cube shaped electrical part plugged into the compressor or wired to it nearby. It may appear burnt or rattle when shaken if it's bad. The two connections should show continuity with an amp meter. If it's good then it's most likely the compressor causing the problem.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Jul 28, 2011 | Samsung RFG299AARS Stainless Steel (285 cu...
Freezer doesn't seem cold enough, took over 24 hours to make ice cubes!!! Small fan at the back of the freezer doesn't seem to work regularly, fridge seems ok
If the fan in the refrigerator (evaporator fan) isn't working properly your machine isn't going to be as cold as it should be and your ice maker won't work properly as well. This is due to the fact that the ice maker has a sensor in it and it won't produce ice unless the sensor tells it is lower than 10 degrees F. A rule of thumb is if the condensor fan motor is running, which is the fan located by the compressor, than the evaporator fan should be running as well. Now, with that said, there evap fan is tied into what they call a bi-metal thermostat. Depending on the brand these sometimes go bad causing the fan not to run, but that wil cause it not to work at all. If its working intermitantly, than chances are the fan motor is bad.
Nov 08, 2010 | Refrigerators
Blue Ice cube maker only make 4 instead of 12 cubes ?
It may just need a cleaning. Use approved cleaner for this modle and sanitize the bin after the cleaning. If it is making some ice, most likely there is not an issue with the charge.
Jan 22, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Water is leaking inside the refrigerator and the ice cube aren't freezing completely (cube is a hollow shell of ice)
Possibly it is because fridge is not cooling correctly(Ice cubes hollow).. Suggest proper defrost. if it is cooling partially, it shows cooling is trying to take place (Make sure before you switch on after defrost, check for proper water drainage.Water must flow to the compressor once defrosted.Take note if the fan runs correctly.
Sep 20, 2009 | Whirlpool 18.9 cu. ft. Top Freezer...
My refrigerator has unusually high temp... 77 degrees and counting.. nothing unusual in the last 36 hours. may have started to creep up yesterday. the freezer seems to be working fine and nothing is...
The most common cause of inefficient refrigeration is dirty condenser coils or a defective condenser fan (the fan at the bottom of the refrigerator that pulls air across the coils).
Try the free fix first... Clean the coils. And while you've got the panel off, see if the fan's running.
Hope this helps.
Jun 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer always about same temp as the upper refrig section
Check those coils underneith. They are making the machine work harder IF they are dirty. They may be full of lint and cobwebs. All that needs to be removed.
Mar 31, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Fan in freezer - evaporator fan?
HI. thanks for the question. yes the fan in the freezer must be replaced.and also the drain tube in the freezer, is clogged. cut power to the fridge. remove back panel . replace the fan motor . also clean ice build up. clean drain tube, from freezer to the drain tray, at the back, near the compressor. thanks the appliance doc. please rate my answer. thanks
Oct 07, 2008 | GE GTS22WCP Top Freezer Refrigerator
Refrigerators Logo
116 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
