Question about Intel D101GGC Motherboard
Sound card is not detected - Intel D101GGC Motherboard
  • Intel Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Apr 01, 2011
Not detected
try to fix the card in your neighbour system, if not detect replace the card, if detect replace your pci card
Oct 19, 2010 | Creative Labs Sound Blaster Live! 5.1...
I have windows xp. the problem i am encountering is that my pc detects the Firewire audion interface intermittenly. when i unplug the firewire cable and reconnect it again it seems ok, but disconnect...
Sounds like the Sound Card is faulty if it can't be detected all the time. I would say to return that sound card and get another one of the same make and model. If it does the same thing then you know that sound card is not compatible with your moterboard, at that point I would try looking for updates for that sound card to see if there are any fixes for it.
If the new one is recognized and works fine then you know the original one is faulty. Also try that sound card on another computer to verify if its a motherboard issue. It might work fine on another computer.
Apr 29, 2010 | Behringer FCA202 - FireWire Audio...
Soundcard cannot be detected
It needs a driver, install from the Asus software and driver disc, or download it from http://support.asus.com/
Apr 23, 2010 | ASUS Computers & Internet
Sound card cannot be detected
  • you remove sound card from the computer.
  • And again Insert in other slot.
Check the computer hope it will work. then no sound card detected. Replace the sound card or have a local tech take a look at the sound card.
Mar 12, 2010 | Computers & Internet
My computer can not detect my sound card
Match your sound card such that it must be compatible.with your motherboard.
Oct 02, 2009 | Computers & Internet
Sound card not detected
Try to use a recent Fedora LiveCD to test the sound card. If sucessful install from the LIveCD and problem solved!
Feb 20, 2009 | fedora Linux Operating System
I lost My Sound Card CD and i want to download the same cd via the Internet how can i do it.
Aug 12, 2008 | Creative Labs Sound Blaster Live! 5.1...
Device detection
Need to check bios first for any on board sound auido devices that are enabled and disable it. Try to restart windows and see if detects. If it doesn't work then try to move the sound card to another slot on motherboard and restart computer.
Aug 09, 2008 | Aureal MTC Vortex Advantage PCI Sound Card
I cannot get the sound to work between computer and speaker. Have looked at and tried all software options. Is there something else i can do please
Hi sallianne!
Let me help you with your concern.
STEP 1: Check if the sound card is being detected by clicking on the Start button, then select Run, and type in "devmgmt.msc".
STEP 2: Check the "Sound, Video and Game Controllers" if there are bangs on the devices or if the Sound Card is being detected.
STEP 3: We are trying to figure out if the sound card is being detected or not, because if its detected by your system and there are bangs you need to install the driver for your sound card. Or if its not detected, you might try unplugging the sound card and plugging it back to the computer but if that still doesnt work, you need to replace the sound card.
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Jul 27, 2008 | Computers & Internet
Sound problem
First of all when you installed the sound card and turned on your pc did your operating system detect the sound card. If it did then you would need to install the software driver. In some cases the operating system will have it built it and configure it on its own. If you installed the software and it you still got no sound, Go to device manager and find the sound card. If its there, right click and update driver. If is still does not do it then right click and remove driver. Restart your computer and it should detect your card and then reinstall software. now if it still does not work or detect your card then possibility bad sound card. Hope thats helpfull to you.
Jun 09, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Intel D101GGC Motherboard Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
