THE TOUCHPAD MOUSE JUST QUITE WORKING DOES IT NEED REPLACE AND IS IT SEPARATE FRON THE KEYBOARD
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
It is hard to tell if the touch-pad needs replacing from the information you gave. However, I can tell you that the touch-pad is NOT part of the keyboard.
There are several things the can cause the touch-pad not to work. 1) It may have been turned off in the BIOS. 2) It may have been turned off by the operating system software or 3) You may have installed a usb mouse which in some cases will override the touch-pad. 4) The touch-pad may have a bad connection into the motherboard or into the touch-pad circuits.
I wouldn't go replacing the pad until I had tried all the other possible areas because this requires a complete screw removal from the bottom, removing the display and keyboard. Then removal of the upper case of the laptop. I do this as a last resort.
Posted on Apr 01, 2011
Turn on touchpad on
Do you mean the mouse buttons below the touchpad do not work but the actual touchpad does? If so I would try removing/reinstalling your touchpad drivers. If that holds no success I would consider replacing the touchpad hardware.
Mar 20, 2014 | Computers & Internet
I spilled coffee on my laptop and now the mouse does not work and I am at a loss on what to do I am not sure if I have completely wrecked the mouse by doing this or not :(
Im afraid it sounds like the touchpad mouse would need replacing. You can find the part quite cheaply on Ebay, but the fitting is complicated and costly to have an engineer do. If you can, use an external USB mouse until you can have it repaired.
Oct 19, 2010 | ASUS Laptop Keyboard for Asus A3, A6, A9,...
Touch pad quit working - locked
Check the mouse setup in control panel - many can be turned off but you have to use keyboard steps to get to the controls under mouse for the touchpad. You can also download a live CD like Ubuntu, burn to a Cd and boot from that and if the touchpad works in Ubuntu then it is the driver software in the off setting. If the Ubuntu or other OS live CD yields a dead touchpad then the touchpad itself has gone bad, or the connector on the motherboard has loosened, or the controller on the motherboard has failed. Troubleshooting the dead hardware will incur getting replacement hardware to isolate it - get a used touchpad or palmrest with touchpad included from a reseller on ebay or a place like laptopaid.com that fits your model. It will involve disassembly to install.
One way to get to the mouse/touchpad settings is to hookup a regular USB mouse then boot so you wont have to use keyboard shortcuts. Check the settings, turn the touchpad on if it's set to off then disconnect the USB mouse and you should be good.
Jun 13, 2010 | ASUS S 1000 Notebook
How do i disable the touchpad so i can use a ps2 mouse? Ican't find any instr. i have an inspiron 1521
You don't need to disable the touchpad.  A touchpad and mouse should both work quite happily together...you just use whichever is most comfortable/nearest at the time.
Mar 03, 2010 | Dell F3534 Touchpad
Touchpad not responding in netboook
There's a little button right above the touchpad. If the light on this button is orange, the touchpad is disabled. Press it again until the light is white again and your touchpad should work.
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
Touchpad and cursor keys quit working
I used to get this problem. It is VERY annoying as you must know. try pushing the windows icon button in the top right corner of your keyboard(thats where it is on my keyboard)then use your arrow keys to scroll up to control panel, select mouse by using arrow keys and then use the tab and arrow keys to open the mouse keypad pagetab and push enable and enter key to turn it on.
IF WHEN YOU DO THAT AND your in the touchpad properties but there is no 'enable' and it says no hardware detected, then go into the same mouse window from the control panel and go to the hardware tab and either try to update driver or use the trouble shoot button.
Hope this helped =]
May 27, 2009 | Dell F3534 Touchpad
Inspiron 1520 Can't turnoff touchpad. Unable to connect to Synaptics pointing driver. Find my cursor in random spots all over. Help!! Thanks
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, check & make sure that your touchpad is disabled.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
If you cannot find a tab to set up your touchpad, then your touchpad drivers might not be installed. In this case, you will need to install them first.
If the above does not work, then you might consider carefully opening your laptop and disconnecting the touchpad. Most laptops will run fine without it. However, beware that since all laptops are very different it might even then not be easy or possible to disconnect just the touchpad; it's possible that it's an integral part of the keyboard assembly, which means that you will be practically disconnecting both the touchpad & the keyboard.
If this either did not work, then you might consider replacing your touchpad (and/or) keyboard.
Apr 08, 2009 | Dell F3534 Touchpad
Acer 3500 mouse touchpad totally frozen
have you tried updating the driver
or go to control panel and mouse and check the settings in there
does your laptop work with a normal mouse
Nov 19, 2008 | Acer Aspire 3100-1405 Notebook
Touchpad dead, keyboard erratic
Go to my computer, right click>properties>hardware tab>device manager, then look down the list for mice and pointing devices, click the '+' sign and right click on your touchpad and select uninstall, do the same on the keyboard line and then restart the pc.
Both touchpad and keyboard will be reinstalled and then ready to use again as it should be back to normal
Sep 10, 2008 | Acer TravelMate 4001WLCi PC Notebook
Presario 2100 compaq laptop/mouse is not working
is it the keyboard or touchpad ribbon cable you need?
Nov 22, 2007 | IBM Lenovo Mouse 76H6618
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
