Showing f02 - Washing Machines
  • 17,970 Answers
Error Code F02 = Motor jammed or tachogenerator detached
Check the motor hasn't jammed up somehow, or that the small tacho coil on the end of the motor hasn't dropped off (tip the machine back and it's in between the brushes - it should be held in place with a clip. If it's hanging loose it's the fault)
This fault code basically means the PCB cannot detect any impulses from the tacho coil on the motor, so the main implication is that the motor is just not running. However, because other fault codes cover most of the other motor faults, the PCB thinks the motor may be physically jammed. That is, as far as the PCB is concerned, it is supplying the motor with power, but it can't detect the motor is running. This fault is not caused by worn carbon brushes because on these washing machines, an open circuit on the motor causes the washing machine to do nothing at all. It would not fill, or empty (as well as the motor wouldn't run) although the indicator lights would work. These washing machines do not produce an error code for open circuits in the motor.
Hope this helps (remember to rate and comment this answer)
Posted on Apr 01, 2011
My Cda washing machine is showing f02 fault code
CDA WASHING MACHINE CI931IN SHOWS FAULT F02 ..not sure if this is your model..when you go to this page just scroll down the page and you will see what you need to read.do not fill any thing in.
Nov 20, 2016 | CDA Washing Machines
I have a problem with a f02 error
The washer is not finishing the cicle and is showing error f02
Aug 03, 2013 | Maytag EPIC MFW9600S
Showing f02 error code
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
May 19, 2010 | Kenmore Elite 45986 Front Load Washer
My oven is saying "stop" . Previously to this is was showing F02 and the fan wouldn't turn off. We turned the main switch for oven off and back on and it now says "stop"
Previous fault F02 is indicating an overheat fault- service manual says to replace main electronic control board. However, switching off at wall has reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears- sometimes switching off at wall will clear fault. Good luck!!
Mar 16, 2010 | Whirlpool AKZ159IX Oven
F02 keeps showing on display
If, after
four (4) minutes the pressure switch still senses foam in the wash tub, the Central Control Unit will
go into Failure Mode. The digital display will show, F02.
Cause: wrong detergent, too much of the right detergent, detergent placed in wrong compartment.
Feb 18, 2010 | Whirlpool GHW9400 Duet Washer
F02 shows on my washer...what does this mean
The F02 Code usually means the washer machine can't drain the water. Usually caused by a failure of the drain pump or a clog in the drain hose.
Dec 20, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
What do the F11 and F02 mean?\
hiyas here is the meaning for the codes
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
F11 Means
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check CCU
• Check Motor
Replace failed component.
I would suggest that you possibly call out an engineer
Jul 20, 2009 | Whirlpool Washing Machines
Persistent F02 / SUD error. Tried all the tricks!
how about the line from pump to bottom of tank?not excess suds?might be bad control bd..f code is generated when control bd senses incorrect current draw by drain motor ..could be glitch in readings or a misread
Nov 02, 2008 | Kenmore 4292x Front Load Washer
F02 Error on Front Load Kenmore HE3
F 02 Is your key pad user interface that has failed. I would call back and get some free service from a different technician.
Oct 23, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
