Question about GPS
Hyundia Santa Fe 2001 manual 2ltr diesel----No reverse lights, I suspect the gearbox switch but where is is it?
  • 17,970 Answers
Generally the Back Up / Reverse Control Switch is located self gear box; look something like this...
Hope helps.
Posted on Apr 01, 2011
Testimonial: "I did not know it was called a back up switch, now I know that this helpful"
  • ZJ Limited
    ZJ Limited Apr 01, 2011
    Additionally, this diagram could helpfull (click over pic for zoom)...
    Fig. BACK-UP LAMPS
I can't turn the dome light off in my Hyundia 2007 Santa Fe, why?
Pull the light bulb. It's easier and it won't disable any other circuits.
Really. The fuse may also power your tail lights, or dash lights, etc.
Sounds like the problem is in the dome light fixture itself.
Aug 19, 2014 | Cars & Trucks
The brake lights wont turn off on my hyundia santa fe
check area at brake pedal to make sure switch is in place and the little rubber bumper is in place for the switch to push into to turn off brake lights. if all that checks ok push on switch to feel it click. you may have a bad switch.
Aug 30, 2009 | 2001 Hyundai Santa Fe
Need a spec sheet for an hyundia santa fe to replace cam belt
Go to www.hmaservice.com and register( Vehicle by VIN). Afterward, you have access to shop manuals, service bulletins, wiring diagrams, etc. about your vehicle.
Aug 04, 2009 | 2001 Hyundai Santa Fe
Where is the trans speed shaft sensor on a 2001 hyundia santa fe?
There are two speed sensors, Input sensor is located on top of the bell house. Output sensor is located on the firewall side of the bell house.
May 25, 2009 | 2001 Hyundai Santa Fe
Engine smoke and doesnt start easy when it is cold
Ones the diesel engine gets weak its thn a hard start!, becausea diesel engine mainly fires up on good compression, i guess its time for an engine overhaul .
May 06, 2009 | 2005 Hyundai Santa Fe
Please help with failure codes p0462 and p0183 on a 2001 hyundia santa fe 4 cyc.
p0462 means - fuel level sensor "A" circuit low.
p0183 means - fuel temperature sensor A circuit high.
try to check those sensor...
Apr 29, 2009 | 2001 Hyundai Santa Fe
Heavy tapping from hyundia 2.0l diesel 2002 model
You need to Do A MANUAL OIL PRESSURE TEST With A Handheld Gage, to First determine that you have Proper Pressure IF YOU DO Try A Valve Adjustment (If Applicable) If Not Then I Would Look into Replacing Lifters
Feb 21, 2009 | 2002 Hyundai Santa Fe
Hyundia santa fe 2002 Headlights won't turn on
head light switch or body control module ,, BLOWN FUSE ON LOW BEAM OR TWO DEAD LAMPS
Nov 06, 2008 | 2002 Hyundai Santa Fe
Describe your 2001 Hyundai Santa Fe Problem
It is electronic
8f21cb3.gif REMOVAL AND INSTALLATION
1. Disconnect the negative (-) battery terminal.
2. Remove the cluster facia panel.
c486b2b.gif 3. Remove the screws holding the cluster and remove the instrument cluster.
bc04bec.gif 4. Installation is the reverse of removal.
Jun 08, 2008 | 2001 Hyundai Santa Fe
GPS Logo
313 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
