Question about Samsung Star GT-S5233 Cell Phone
My cellphone is showing pc connection always and getting charged without connecting it to the charger.what should i do??
    Genius:
  • 1,114 Answers
When an issue such as this occurs, or you have found that your device is freezing, you can reset the device by removing the battery while the device is on, wait 1 minute and then reinstall the battery and power the device back up. Doing this will force the device to re-register with the network. If this does not correct the issue then you are looking at a more serious issue, and may need to have the device repaired, or replaced. If the device is under a year old, then you may be covered under the manufacturer's warranty, and you would need to contact your wireless provider to initiate that exchange.
Posted on Apr 01, 2011
I plug my charger in but it wont charge and when i hold middle button it says charger connected and charges but as soon as i let go it says cahrger is disconnected.
Welcome to Fixya. Possible reason that your charger might have been damaged, or there's a wire that connects from the charger to your cellphones might be loose. Also cahrger connector on your cellphones might also damaged. If you have a friend or relatives that have the same cellphone, I suggest that why dont you try to use their charger on your cellphone or vise versa (your charger to their cellphone). In that way you, you can identify which one is damaged.
Please let me know if you have any questions.
Thank you for using Fixya,
seancarlisle
Apr 30, 2011 | Cell Phones
How do I charge the battery of my ACER note book PC? What is the correct manner to charge it? Should I always plug the Note Book PC into the main AC when I log on to the computer?
Yes you should when the battery is low.
You can check the amount of charge in your battery by -
Open Control Panel - Power Options - click on Power meter tab - un-tick Show power levels on each battery.
Apr 14, 2011 | Acer Aspire One PC Notebook
How to connect htc touch p3450 moble to pc without cd driver
You can connect it with the cable and the cellphone will get charged up.
You can also download ActiveSync from the Internet and install it. Then when you connect the cellphone to the computer, you can exchange files between the computer and the phone by using the Mobile Device icon that appears in you "My Computer".
You can also share your cellphone's internet connection with the computer.
All these can be done without the CD driver.
Nov 23, 2010 | HTC Touch P3450 Smartphone
When i connect my mobile for carging it show (not charging(stop)). But it show after few second and make a beep. with this mobile show different status of charge level.
Hi, I too have this cellphone, when this happened to me I just bought a new charger and that fix my problem. I would suggest you try first a known good charge for your cellphone and if still you have the same issue, try to visit a cellphone repair center or from nokia care center, because there is already a problem with the charget socket on your cellphone. Hope This Helps
Jun 11, 2010 | Nokia 1110 Cellular Phone
My 3200 will only run when plugged into charger, won't charge bat
Try dusting the connector pins on your laptop and connecting the battery back.
Jun 24, 2009 | Averatec 3200 Notebook
Can't connect charger's cables to battery without sparks
NEVER connect positive to negative. You'll damage your electrical system in the car or fry the charger.
It is best to put the positive on first, and then the negative. Remember, it doesn't always have to be the negative post of the battery, it can be a really good ground on the bare metal of your car.
But sparks just go along with it - don't let them scare you. But I always connect the clamps first, then turn on the charger, with the dial on "off". Then make sure of the 6/12 volt settings, and the amp charge you want to put on. A long slow charge overnight fo 12 volt can be 10 amps. A relatively fast is 50. And then to jump it off, go to the setting.
Make sure the battery being charged is sitting in wood, not concrete. If you have the old fashioned battery with removeble water caps, don't breathe the vapors.
May 28, 2009 | Schumacher & Fast Charge Starter Charger
Have a motorola v3X Suddenly not charging
Just replaced a new cable or a new charger so you sure where is the defected even if battery defected it will charge but the battery it will not last long.If you replaced already new cable but problem still exist then the problem is the cellphone hub is crack or cold solder,you need to rebuild or resoldered it so it will works normally.
Got to cellphone to perform the soldering.
Hope it may help you;
Regards;
VOTIT
Jan 14, 2009 | Nokia 3650
K1 Problem Charging Battery
sounds like the battery to me. there is a chance it is the phone. Check on your warranty and see about a battery replacement first. Its much more likely.
Jan 13, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung Star GT-S5233 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
