Question about Western Digital Caviar WD400BB 40 GB Hard Drive
I have a gateway and am trying to replace my current hard drive with the Western Digital Caviar WD400BB 40 GB Hard drive . I currently have 2 maxtor drives in that are op as 1 partition. I hook it up but its not seeing it. I want to format it and load windxp home
  • Western Digital Master
  • 27,725 Answers
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Master/Slave designation is determined by jumpers on IDE drives. Most drives have adequate markings on them to identify these jumper positions. If not marked clearly, you will need the manufacturer's data to determine that designation.
If you are curious about a working system just power-up in set-up mode (usually by depressing (f1-or-f2) during boot-up sequence, your system-bios will display this information for you.
Posted on Apr 01, 2011
  • Brian Sullivan
    Brian Sullivan Apr 01, 2011
    One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
    Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
    the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
What is the nutral position sinle jumper settings
Jumper Settings: The Western Digital hard drive is factory set for single drive installation. Western Digital hard drives are shipped with a jumper in the neutral storage position (across pins 5 and 3) for future dual drive use. If you are installing the Western Digital hard drive as the only hard drive in your system, leave the jumper in the neutral storage position. Jumpers are not required for single hard drive installations.
For more information visit this link http://support.radioshack.com/support_accessories/doc33/33085.htm
Apr 25, 2015 | Western Digital Caviar® WD400BB 40 GB...
Disk error
Please clarify your problem giving the problem details, your system configuration and other information(if you think them to be useful), otherwise we are unable to give the proper solution for you.
Thanks,
Mrityunjay.
Apr 03, 2011 | Western Digital Caviar WD400BB 40 GB Hard...
How do set the jumpers on the HD to slave ? thanks
you can find the jumper settings printed on the top of western digital caviar hard drives
slave setting with the hard drive end jumpers facing you is 2nd from the right or 4th from the right
good luck
Aug 28, 2010 | Western Digital Caviar WD400BB 40 GB Hard...
Need to know what is jumper setting for cable select on all western digital hard drives
Welcome to Fixyah,
Jumper settings procedure will located at the front of that disc and it will show where the jumper setting was located. I suggest to you to go ahead and check it out.
Aug 11, 2010 | Western Digital Caviar WD400BB 40 GB Hard...
I would like to add this hdd to my system as a second drive ....what are the pin settings needed?
hard drive pin settins are usually printed on the top or the back of most hard drives you Press either f2 or delete during the boot process to enter computer BIOS you can change the drive settings in there
be very careful
Jul 29, 2010 | Western Digital Caviar WD400BB 40 GB Hard...
Caviar 40 GB jumper settings
WD400BB/LB Caviar HDD Jumpers
Set the jumper(s) for your specific installation requirements according to the picture.
Dec 28, 2009 | Western Digital Caviar 40 GB Hard Drive
Western Digital Caviar WD400BB 40 GB Hard Drive Logo
187 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
