Question about Lowrance PC-19BK POWER CORD FOR: LMS-160 MODEL 99-39
Need a power cable for lms 160 map PC-19BK - Lowrance PC-19BK POWER CORD FOR: LMS-160 MODEL 99-39
Lms-332c lowrance fishfinder unit turns on as soon as the power wire is plugged in and goes to blinking pinging beeping between hi and low light settings constantly. All other features seem to work fine. A...
Hello
I don't know whether you have made a factory reset to this device or not. If not, set it first and see whether it helps you. To make it factory settings:
[1] Press 'MENU""MENU" (down arrow to system setup) "ENT" (down arrow to RESET options/ ENT
[2] The unit asks if you want to reset all the options. Press [<---] to YES and then ENT. All options are reset, and the unit reverts back to map page at 4000 miles zoom range. Any recorded sonar logs of GPS data will be unchanged. OK.
Sep 23, 2011 | Lowrance LMS-332C GPS Receiver
I have a lcx 110 lowrance graph that wont power up at all. i replaced all the wiring to the unit and tested the plug at the unit all of that is good i also cleaned the connections still nothing. any ideas?
I have found several units that have the same problem. All turned out to be a defective keypad. And almost all are specifically the power button. Not something Lowrance will repair. I've been purchasing some of these units for parts. If you still have it I might be interested. jadamec@yahoo.com
Aug 23, 2011 | Lowrance LMS 332c Mapping Sonar/GPS...
Lowrance completely dead
my lowrance lms 337c df will not power up. I checked all the cables and poer and they are good . can you assist me
Aug 14, 2011 | Lowrance LMS-337CDF GPS Receiver
Units flashes when turned on --won't stop
Here's my LMS 332c circuit board. I'm showing where the power source is on the lower right, and where I believe the first two ribbon cables that lead to the power switch on the front panel (upper left). Can anyone tell me how to disable the internal power switch and where? I want to install external switch and bypass the internal. I can solder and not afraid to try since this unit is out of warranty and is not functional as is with powering on/off and screen flashing randomly. Thanks!
Apr 08, 2010 | Lowrance LMS-332C GPS Receiver
Won't power up
Make sure the power is good, and the power connections are clean. Check fuses and connections. You can even get a volt meter, unplug the power cable and test for 12VDC across the two bigger female contacts on the power cable connecter. If you are getting 12VDC, then the LMS-520 is bad. If you are not getting 12VDC, then you have a bad power supply, connection, or cable.
Jul 10, 2009 | Lowrance Lms 520c 5" Screen Color External...
Hi,when i switch on my lms-332c the map does not come up on the screen.If I remove and replace the map card it works perfectly. Can I fix this? regards nigel
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
Jul 08, 2009 | Lowrance LMS 332c Mapping Sonar/GPS...
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
Cannot access main menu or pages screen
I think I can help with your issue. I have an LMS 334c and have had a few issues in the past. Called the factory (this answer is not listed any where in your manual) and they instructed me to "Soft Re Boot" my unit and it would put everything back to factory settings. Try this anytime it does not respond for whatever reason.
Turn the unit off.
At the same time press the Pages and Power button. Hold both down until you see the square box come up in the screen. You should have your factory settings again. May need to try a few times.
Lowrance said it works just like a computer, ever now and then it just tries to disect to much information at one time and hangs up.
Good luck. James Cantwell
Nov 03, 2008 | Lowrance LMS-330C GPS Receiver
I have a lowrance lms332c and the unit powered off , was able to restart.shortly after powered off again and now has nothing.checked fuse and fuse is ok.
try to hold in the page button and power button at the same time to reboot your unit, But you may or may not lose waypoints,
Jul 11, 2008 | Lowrance LMS 332c Mapping Sonar/GPS...
Gps module not responding
i found that it was the gold maps in the mmc card reader. Remove card and see if it fires up. Also i can be the 60 ohm resister on the NMEA 2000 y cable
May 14, 2008 | Lowrance LMS-330C GPS Receiver
Lowrance PC-19BK POWER CORD FOR: LMS-160 MODEL 99-39 Logo
120 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
